Fracarro Antennas - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 61 Old 07-13-2012, 06:04 PM
tylerSC's Avatar
Quoted: 726 Post(s)
Liked: 167
Ability HDTV now has a new version of their low noise preamp that is integrated internally into the antenna balun on most Fracarro antennas, as well as their channel specific Datawave antennas. The Fracarro 920 antenna is similar to the 91XG, but appears to have better build quality and perhaps better gain. And combined with the new internal Datawave low noise preamp, it sounds like that could be a very good set up for UHF fringe reception.
tylerSC is offline
Reply HDTV Technical
