Monster Surge Protector Hums Loud Noise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-17-2011, 07:24 PM - Thread Starter
trophybuck135's Avatar
Hey guys, my surge protector makes a loud humming noise and the only way to disable it is unplug it.
After hours of leaving it unplugged it still remains
please advise
thanks
trophybuck135 is offline
post #2 of 9 Old 01-17-2011, 11:19 PM
Colm's Avatar
Liked: 94
Why would it change?
You didn't mention the model of your device, so we can only speculate generally. Could be the windings of an inductor or transformer vibrating, or the way the component is mounted. If so, only way to eliminate the sound would be to replace the offending component or the entire unit.
Colm is offline
post #3 of 9 Old 01-18-2011, 01:54 PM - Thread Starter
it is a Monster Power HTS 1000 MK II
can you update the diagnosis
thanks
post #4 of 9 Old 01-21-2011, 02:48 PM
RickCain2320's Avatar
Sounds like its defective. Monster charges a LOT for their stuff, it should have a lifetime warranty, so use it.
RickCain2320 is offline
post #5 of 9 Old 01-21-2011, 07:44 PM - Thread Starter
yes sir you are right they SHOULD have a lifetime warranty but they told me 5 years mine is a year past that and they will offer me a new one at 50% discount but I don't know that is poor service imo
still thinking
post #6 of 9 Old 01-24-2011, 10:15 PM
Colm's Avatar
Liked: 94
Nonsense. They owe you nothing because you are out of warranty. And they still offered you 50% off. That is good customer service.
If you expected a lifetime warranty, you should have made sure of that before you bought. You would have had a hard time finding it. MOV based surge protective devices have a limited, although not necessarily short, lifetime.
Colm is offline
post #7 of 9 Old 01-25-2011, 10:15 AM
McDonoughDawg's Avatar
Quoted: 20 Post(s)
Liked: 31
I will agree that usually Monster stuff is WAY overpriced..that said, they are being generous in trying to help you out a FULL YEAR out of your warranty.
Peachtree City Golf Cart Rider
McDonoughDawg is offline
post #8 of 9 Old 02-03-2011, 02:19 PM - Thread Starter
if im going to have to buy something new, is anything better then a high end surge protector?
post #9 of 9 Old 02-03-2011, 02:53 PM
JimboG's Avatar
A whole house surge protector mounted at your circuit breaker panel for ~$200 makes a lot more sense than a plug in surge protector attached to just one wall socket.
Free over the air HDTV + Tivo HD + Netflix for Blu-ray and streaming = Bliss
JimboG is offline
Reply HDTV Technical
