TV Audio to an HDMI SoundBar... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-20-2011, 01:09 PM - Thread Starter
netengineer10's Avatar
I currently have a Yamaha HDMI Soundbar YHT-S400BL. I am looking to upgrade my TV but these newer TV's have built-in streaming from Netflix, Pandora, etc. LG calls it LG NetCast, Panasonic calls it VierraCast, etc.... My question is this. How do I send audio-out to my soundbar when I only have HDMI to work with? If i connect an HDMI cable between them, will the TV send audio-out to the receiver when streaming from its internal streaming media player?
netengineer10 is offline
post #2 of 5 Old 01-20-2011, 01:30 PM
Ratman's Avatar
Quoted: 1475 Post(s)
Liked: 1180
Run an optical cable from the TV's output to the soundbar's optical input.
An HDMI will only work if both the TV and the soundbar support HDMI with ARC (audio return channel).
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 5 Old 01-20-2011, 01:45 PM - Thread Starter
Will that downgrade sound quality at all? Not noticeable in a soundbar setup?
post #4 of 5 Old 01-20-2011, 03:31 PM
Ratman's Avatar
Liked: 1180
No problem/degradation whatsoever.
Ratman is offline
post #5 of 5 Old 01-20-2011, 08:07 PM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 46
As Ratman indicated no degradation of sound. However you need to be aware that Netflix and Pandora at this time do not stream dolby digital audio, so don't blame the setup or sound bar when you don't get dolby digital from Netflix or Pandora.
HDMI Guy is offline
Reply HDTV Technical
