Directional Antenna into router HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 02-11-2011, 01:01 PM - Thread Starter
andrey64's Avatar
I have been wanting to purchase a 24dbi Directional grid antenna and mount it on top of my home(approximately 15-20ft high) and run the cable into the house. Is there any way possible that I can connect the antenna into a wireless box and have the signal shot around in the house? I have the 1000mw usb adapter to my laptop and i want to make it wireless in the house.
Is this possible to do? and if so,whats the best way to do this. Please help.
andrey64 is offline
post #2 of 22 Old 02-12-2011, 06:31 PM
arxaw's Avatar
No. You need to run coax.
arxaw is offline
post #3 of 22 Old 02-12-2011, 07:16 PM
Tschmidt's Avatar
I'm a little confused by what you are asking.
1) Are you trying to connect a high gain external antenna to a Wifi adapter to increase wireless network range?
2) This is an HDTV forum. Is the antenna to pick up over the air (OTA) TV programs?
3) Something else.
Tschmidt is offline
post #4 of 22 Old 02-13-2011, 09:44 AM
JimboG's Avatar
I'll take a stab at this. You could connect your over the air TV tuner to an HD Homerun tuner and then send the TV signal from the Homerun over your network.
Free over the air HDTV + Tivo HD + Netflix for Blu-ray and streaming = Bliss
JimboG is offline
post #5 of 22 Old 02-14-2011, 03:06 PM - Thread Starter
andrey64's Avatar
3) Something else.
What i am trying to do is connect this antenna so that i can get my friends wifi(about 1/2 mile) so i can watch tv online. is this possible to somehow instead of having it only go to one computer,have it into a wireless box that i can connect to wirelessllythough my laptop.
yes i know its an HDTV post, but nobody else knows more about topics like this then people likke you guys.
andrey64 is offline
post #6 of 22 Old 02-14-2011, 04:59 PM
Colm's Avatar
Liked: 94
I think you might be able to do what you want with an ATSC tuner (STB), a Slingbox, and a wireless bridge. Good luck with your friend's wifi being a 1/2 mile way, though.
Colm is offline
post #7 of 22 Old 02-14-2011, 11:19 PM - Thread Starter
andrey64's Avatar
weelli can catch a bar through my laptop
andrey64 is offline
post #8 of 22 Old 02-15-2011, 06:18 AM
Tower Guy's Avatar
Buy two of these: http://www.streakwave.com/Itemdesc.a...letM5HP&eq=&Tp
Get a pair of 5.8 GHz directional antennas. http://www.streakwave.com/Itemdesc.a...D53-21&eq=&Tp=
Aim them at each other. Pick locations that can see each other. Plug one end into your neighbors router using a hard wired Ethernet cable, plug the other into your wireless router.
You will also need a pair of Power over Ethernet (POE) adapters. http://www.streakwave.com/mmSWAVE1/V..._Datasheet.pdf
Tower Guy is offline
post #9 of 22 Old 02-15-2011, 11:23 PM - Thread Starter
andrey64's Avatar
i just want to capture his wifi without having to install anything at his place too. i want to capture it and connect to a computer. the question im asking is that i want to capture it and make a wifi spot inside my house while connected to his network.
andrey64 is offline
post #10 of 22 Old 02-16-2011, 07:15 AM
Tower Guy's Avatar
You need more than just an antenna. This device claims to do what you need, but real life implementation may not solve your problem.
http://electrodisc.com/linksys-wrt16...SD&language=en
Here's a story about the process. http://lifehacker.com/#!178132/hack-...o-a-600-router
You really need a device with two antennas, one aimed at your neighbor's, the other inside your house. They must be on different channels. Most routers come programmed for channel 6. The only non overlapping channels are 1 or 11. I don't know if you can use two routers back to back to achieve the same goal.
post #11 of 22 Old 02-16-2011, 08:06 AM
Ratman's Avatar
Quoted: 1475 Post(s)
Liked: 1180
Does "your friend" know you're trying to utilize his WiFi/internet connection?
If he's on-board, then he has to install an antenna/x-mitter to boost the signal. Which you should purchase.
If you're trying to just get a "free" signal, how do know he doesn't have/use security (wep/wpa) to lock out unauthorized access?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #12 of 22 Old 02-16-2011, 02:58 PM - Thread Starter
andrey64's Avatar
yes he is my friend. the reason idont want to install it from his side it that its going to cost me extra money i dont have. he has no wep pass because i am able to log into his network with very weak signal from my front yard. i have a clear line of site.
andrey64 is offline
post #13 of 22 Old 02-16-2011, 03:19 PM - Thread Starter
andrey64's Avatar
i dont need coax.i need lmr 400 to not lose the ghz
andrey64 is offline
post #14 of 22 Old 02-16-2011, 03:36 PM
Ratman's Avatar
Liked: 1180
1) he should use wireless security
2) radios in wireless has it's distance limitation(s)
3) your choices are antennas or run a 1/2 mile of Cat6 from his house to yours.
Either way... it will cost you.
Maybe you should just get your own internet connection/provider.
Ratman is offline
post #15 of 22 Old 02-17-2011, 05:06 AM
serndipity's Avatar
You said that your laptop is receiving the signal with 1 bar.
If the laptop's antenna has no gain, the 24 dB antenna will increase the signal power by 256 times. Aiming will be important as the beam width will be very narrow.
You may or may not require a low noise antenna pre-amplifier (e.g. must be capable of amplifying signals in the GHz range).
To get the signal into your laptop, connect the above to a 2nd antenna, located near the laptop.
serndipity is offline
post #16 of 22 Old 02-17-2011, 02:56 PM - Thread Starter
andrey64's Avatar
thank u serndipity . awesome. finally someone who actually gives a good a good answer. i have the 24dbi grid. should i get the alfa or a friend of mine actually has a pannel antenna he bought for like 150. supposedly its better cuz its a 20dbi antenna plus its got a built in ralink 30dbi adapter. what should i use?
andrey64 is offline
post #17 of 22 Old 02-17-2011, 03:03 PM
Ratman's Avatar
Liked: 1180
Looks like you think you're on the right track. Let us know how it works out.
Ratman is offline
post #18 of 22 Old 02-17-2011, 04:11 PM - Thread Starter
andrey64's Avatar
thanks alot everyone.
andrey64 is offline
post #19 of 22 Old 02-18-2011, 05:51 AM
Tower Guy's Avatar
yes he is my friend. he has no wep pass because i am able to log into his network with very weak signal from my front yard. i have a clear line of site.
You are taking unfair advantage of your neighbor. I'm sorry that I offered any suggestions.
post #20 of 22 Old 02-18-2011, 12:00 PM - Thread Starter
andrey64's Avatar
i actually ended up taking an old panel antenna and plugging it in at his home and using another at my house. so im not taking advantage.
andrey64 is offline
post #21 of 22 Old 02-18-2011, 12:27 PM
McDonoughDawg's Avatar
Quoted: 22 Post(s)
Liked: 35
I still don't think this is the proper forum for this question..that said, carry on.
Peachtree City Golf Cart Rider
McDonoughDawg is offline
post #22 of 22 Old 02-18-2011, 01:30 PM
Super Moderator
DrDon's Avatar
Quoted: 1261 Post(s)
Liked: 2430
I think you're right. Probably should be in HTPC or streaming area. That said, looks like it's run its course, anyway. Thread closed.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Closed Thread HDTV Technical
