What's the difference between these antennas? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-24-2011, 07:29 PM - Thread Starter
hn333's Avatar
hn333 is offline
post #2 of 11 Old 02-25-2011, 01:08 AM
Colm's Avatar
Liked: 94
Well, the thing that is similar about them is that they are both two-bay bow tie UHF antennas. Performance and construction may differ somewhat, though.
Colm is offline
post #3 of 11 Old 02-25-2011, 08:05 AM
arxaw's Avatar
hn333, I can tell you firsthand, the build quality of the Eagle-Aspen is excellent. It is a great, sturdy outdoor UHF antenna, if UHF is all you need. I have purchased several of those in the past. Some antennas from antennas direct are also good, but IMO, many are overpriced, including the one you linked to.
arxaw is offline
post #4 of 11 Old 02-25-2011, 11:01 AM
Tower Guy's Avatar
Originally Posted by hn333 View Post
Other than the price
The difference is that the cheaper antenna is below the threshold for free shipping.
You did need a splitter and a jumper cable too, right?
Tower Guy is offline
post #5 of 11 Old 02-25-2011, 07:18 PM - Thread Starter
hn333's Avatar
Thanks for the feedback. Looks like just the antenna I need.
hn333 is offline
post #6 of 11 Old 02-25-2011, 09:37 PM
Ken H's Avatar
What's the difference? The difference is a non-specific topic title will get fewer responses.
Topic title edited.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #7 of 11 Old 02-26-2011, 12:33 AM
coyoteaz's Avatar
The difference is that anything that says Antennas Direct on it has a 40% markup just for the name.
coyoteaz is offline
post #8 of 11 Old 02-26-2011, 08:02 AM
kenglish's Avatar
Liked: 39
Have you checked to be sure there are no VHF channel allocations in your area?
BTW...if there are no DTV channels on VHF, you might want to purchase a small FM antenna (yagi or omni-directional) and a diplexer. That would get you up there in the "free shipping" area.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #9 of 11 Old 02-26-2011, 02:49 PM - Thread Starter
hn333's Avatar
I only have one VHF channel in my area.
hn333 is offline
post #10 of 11 Old 02-27-2011, 05:30 AM
Tower Guy's Avatar
You may not get the VHF station with the DB-2.
post #11 of 11 Old 02-27-2011, 04:53 PM
tylerSC's Avatar
Quoted: 724 Post(s)
Liked: 166
They are both very similar. I think there is mainly a bit of a difference in the balun, but not sure how this effects reception of specific channels. Perhaps DB2 not as good on VHF.
tylerSC is offline
Reply HDTV Technical
