Philips TV Refresh Problem? - AVS Forum | Home Theater Discussions And Reviews
Old 03-27-2011, 07:43 PM - Thread Starter
lehah's Avatar
I just got a Philips 40PFL7505D/F7 40" LED TV today and I'm enjoying it so far. The only thing I have hooked up to it is my Xbox 360 (I canceled my cable box now that I can get Netflix Streaming through the gaming unit) and I bought a GE 6' HDMI cable to run between the Xbox and the TV.
I tried out a couple of things before playing some Force Unleashed 2 (lol) when... not once, but TWICE... the screen went black for about a second. Two seconds tops. And then came back on like nothing happened. It seemed to be almost like when my computer's old CRT monitor use to refresh resolution? Is this something I should worry about?
(Before you ask if I can reproduce this, yes I can: any time I use Netflix Streaming, it blacks out between signal strength and streaming the video)
And does anyone here have a suggestion for the best "setup" for this TV? The manual really doesn't explain what some of the setup options are...
lehah is offline
