Comcast and the Motorola DCH3416 HD DVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-30-2011, 02:50 PM - Thread Starter
wmackey73's Avatar
Hello!
I have Comcast cable television and a HD DVR. I pay $16/month rent for the HD DVR. The DVR is a Motorola DCH3416. I found one online for $50.00. It is identical with same model number as the one I am renting.
I called Comcast and the non-tech savvy, customer service person said that it will not work.
Now, I cannot believe this to be true. There must be a fairly worthwhile way to make this happen.
Any assistance is appreciated.
WM
wmackey73 is offline
post #2 of 3 Old 04-30-2011, 03:00 PM
homcom's Avatar
Believe it.
No US cable company will authorize a cable box like the DCH 3416. They are not sold to the public in the US, so the box is either from Canada or stolen.
Only consumer purchasable units like cable card based Tivo and Moxi would be able to be used.
homcom is offline
post #3 of 3 Old 04-30-2011, 03:23 PM - Thread Starter
wmackey73's Avatar
Originally Posted by homcom View Post
Believe it.
Thank you Sir, for the timely reply.
I have looked into Tivo and they charge a monthly fee also. So that alternative would not suite my particular needs.
It seems with Moxi, the only option is to spend $600 on the 3-Tuner HD DVR. It looks like a fantastic product. It is quite spendy. I might just buy one.
Thanks again.
WM
Reply HDTV Technical
