Channel Plus 5415 HD modulator? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 05-01-2011, 10:47 AM - Thread Starter
Super Moderator
markrubin's Avatar
Quoted: 1035 Post(s)
Liked: 2273
I see listings for a Channel Plus 5415HD single channel modulator which appears to accept 720P component video input
anyone have any experience with this? I know there is a 5415 SD unit but the one I am looking at has an HD suffix and a list price of $1k
I am looking for an HD modulator at a reasonable price
TIA
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #2 of 21 Old 05-01-2011, 02:02 PM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
The Channel Plus site does not show this model so we have no real info on what it can do. How do you expect to feed such a unit (HDMI, Component, file from computer, etc.)?
Wendell R. Breland is online now
post #3 of 21 Old 05-01-2011, 04:37 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
TIA
Mark, using the ZeeVee at work..pleased with it so far:
http://www.zeevee.com/residential/zvbox170
Contemporary Research also makes some nice units:
http://www.crwww.com/QMOD-HD.asp
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #4 of 21 Old 05-01-2011, 04:51 PM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2273
Thanks Bob: I was looking at these too
have you noticed if the ZeeVee fan is noisy?
post #5 of 21 Old 05-01-2011, 05:03 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
Not really, as it is in a room full of really noisy equipment..but I am sure it is quiet compared to the Tandberg and Harmonic QAM moduoators it lives with..
Bob
post #6 of 21 Old 05-21-2011, 09:12 AM
Erik Garci's Avatar
Here are some photos of the 5415HD:
Front
Rear
It has YPbPr input, S/PDIF input, RF output, and a USB port.
Erik Garci is offline
post #7 of 21 Old 05-23-2011, 12:22 PM
Erik Garci's Avatar
The manual for the 5415HD states that the YPbPr input accepts 480i, 480p, and 720p60. It does not accept 1080i. The S/PDIF input accepts 48kHz PCM and AC-3 pass-through. Also, I was told that the MPEG2 output is 720p30 (not 720p60, so it discards half the frames, thus motion is less smooth, and movies are converted from 2-3-2-3 cadence to a jerkier 2-4-2-2).
post #8 of 21 Old 05-24-2011, 05:36 AM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
Price and Avails?
Bob
post #9 of 21 Old 05-24-2011, 06:45 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2273
Originally Posted by bdfox18doe View Post
Price and Avails?
looks like around $600.00 online: but beware if you do a search it may give you the 5415 which is the generic SD modulator for around $60.00.
I am using 2 Channel Plus SVM-24 modulators (4 modulated channels each) into a Channel Plus DA-550 distribution amp and they do pretty well: but am looking for a cost effective way to feed HD throughout the house mainly for distributing DirecTV. The boxes are set for 1080i so the 5415HD might not accept the component video out (right now I use the S video out of the D* box)
The 5415HD looks like it may provide some marginal improvement but perhaps not enough to warrant the cost: strange that no one seems to have experience with this device
post #10 of 21 Old 05-24-2011, 01:48 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
I have one of these at home..I feed it with the SD anamorphic outputs from my Directv receivers..Not HD but excellent quality. And very hard to find for
the $800 I paid for it.
Harmonic RSG 8012 QAM Mod Manual.pdf 292.830078125k . file
Bob
post #11 of 21 Old 06-15-2011, 10:17 AM
Jack Humphrey's Avatar
I've been using a ZVBox 150 for a number of years now. It's rated as a consumer vs. commercial grade QAM HD Modulator and limited to 720P input via component video source. That didn't seem to be a limitation to me when I first acquired the 'box' because, WTF, remote TV's located around the house are typically smaller (screen size) than the master set atop my home entertainment system. So, 720P is just fine, right? WRONG!!!
I quickly discovered that virtually all video sources (set top boxes, DVD players, BluRay, Etc.) sport multiple connections on their rear panel including HD via HDMI and HD via component video. These low end QAM modulators use component input (I think that's to skirt MPEG ownership of the programming that doesn't exist when dealing with base band) and you can't feed them above their 720p rating.
Now, while the picture stream source has different interfaces on the rear panel, it looks like there's only ONE HD video generator inside. That means you can NOT drive a local TV at say, 1080i/1080p via HDMI AND feed the QAM modulator at 720p simultaneously!!!
Yes, I have a component audio/video 'spliter' (push button selector; 3-in, 1-out) that let's me pick and choose what HD video source drives the ZV modulator (DVD player, Bluray player, Dish Network STB). But, the unintended consequence of connecting a given source to the HD modulator is that the HDMI link from that source to my 70-inch primary TV throttles back to 720P in lock-step!!!
Jack Humphrey is offline
post #12 of 21 Old 06-30-2011, 07:46 AM
Erik Garci's Avatar
post #13 of 21 Old 06-30-2011, 08:04 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2273
Eric
Thank you for the link: I was aware of the 720 limitation and decided to wait for a better solution: the report of fan noise is a deal breaker for me by itself
post #14 of 21 Old 06-30-2011, 10:17 AM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
I inquired about the manual from Linearcorp and got this response:
Good Morning ,
i do ndot have the manual you are looking for .
Please contact the Marker-Tech company
______________________________________
Bob
post #15 of 21 Old 06-30-2011, 11:02 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2273
there is a PDF connection diagram on Markertek site (typical application diagram)
http://www.markertek.com/CATV-Headen...s/5415HD.xhtml
post #16 of 21 Old 07-04-2011, 09:05 PM
Erik Garci's Avatar
post #17 of 21 Old 06-07-2012, 06:08 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2273
these modulators are now available from Amazon for around $675.00...got one to check out
hooked it up to the component video out (and digital audio out) of a DirecTV DVR and set its output to 720P: previously the box was set at 480i to feed a Channel Plus S video modulator
The signal is fed to 10 small/ medium size TV's in my house (I feed some larger TV's with 1080 HD via HDbaseT feeds)
I set the modulator to house channel 107: each TV required a channel rescan and saw the modulator as channel 107-1: noticeably better PQ with this modulator than with the 480i solution: I love it
only drawback is the fan noise: this little box has a very loud fan in it ( ZVbox also has a fan I think)
All in all for the money it seems like a nice HD solution
post #18 of 21 Old 06-07-2012, 07:09 AM
AntAltMike's Avatar
Quoted: 129 Post(s)
Liked: 62
...if all ten of you want to watch the same show at the same time...
AntAltMike is offline
post #19 of 21 Old 06-08-2012, 05:12 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2273
I have another SD modulator that provides more channels
post #20 of 21 Old 06-08-2012, 05:14 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2273
more
opening up the Ch Plus modulator: at least one board says ZeeVee Inc on it....
post #21 of 21 Old 06-09-2012, 04:56 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2273
I see the issue with fan noise: they use a 40 x 10 mm PC fan (12 volt 2 wire) which is right below the processor chip which runs pretty hot
the fan is so close to the chip that a lot of fan noise is created: and the opening for the fan inlet is partially blocked by the integrated guard
for now I mounted the fan on the outside of the cabinet and it reduced the noise to acceptable levels: will come up with a permanent solution soon
Reply HDTV Technical
