Terk55 Power Amplifier or Antenna Problem? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-16-2011, 05:34 AM - Thread Starter
neverrude's Avatar
Could someone please tell me how I could check the power amplifier on my Terk55 antenna with a meter. I statred having problems with the reception and I don't know if it's the power amplifier or the antenna.
Output:9vDC
100mA
Thanks in advance.
neverrude is offline
post #2 of 5 Old 05-17-2011, 11:32 AM
SAM64's Avatar
Liked: 78
I'm assuming you mean the power supply.
Place one probe on one of the wires, the other probe on the other wire, and read the voltage.
SAM64 is offline
post #3 of 5 Old 05-18-2011, 10:25 AM
JimboG's Avatar
I had a Terk TV55 some years ago. It was an overpriced piece of junk.
Adding a cheap amplifier to a simple dipole is not the best way to make a quality antenna.
If you would like, you can post your TV Fool results for your reception location and get some recommendations for an appropriate TV antenna that will work better and cost less than the TV55.
Free over the air HDTV + Tivo HD + Netflix for Blu-ray and streaming = Bliss
JimboG is offline
post #4 of 5 Old 05-18-2011, 11:57 AM
Ratman's Avatar
Quoted: 1296 Post(s)
Liked: 1035
To elaborate...
If you or a friend has a multimeter, test the DC output voltage of the power supply. Set to "DCV" and place the red probe on center and black probe of the outside. If it reads ~ 9VDC, the power supply is good.
If your reception suddenly went to crap and the power supply tests "good", then the amplifier (the bullet/injector) is bad.
Ratman is online now
post #5 of 5 Old 05-20-2011, 03:48 AM - Thread Starter
neverrude's Avatar
I did as you said and found it was the power supply. I replaced it and it works perfect again.
Thank you gentlemen
Reply HDTV Technical
