How lossy are coax angle fittings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-31-2011, 08:11 PM - Thread Starter
LithOTA's Avatar
Given that it's best to mount the preamp as close to the antenna as possible, the use of 2 90-degree angle fittings can allow for only a few inches of cable. The balun's jack and preamp jacks all face down.
But are those angle pieces lossier than another 6-12 inches of RG6 would be? Am I robbing Peter to pay Paul?
LithOTA is offline
post #2 of 4 Old 05-31-2011, 09:40 PM
Colm's Avatar
Liked: 94
Just the cable. The extra loss from an extra foot of cable is inconsequential and the cable will be more reliable.
Colm is offline
post #3 of 4 Old 06-01-2011, 04:54 AM
kenglish's Avatar
Liked: 40
Adding an extra set of connections, by using 90-degree adapters, is just as lossy as a few extra feet of cable.
And, I've had bad luck with both those, and the all-in-one-piece 90-degree connectors...they are usually press-fit together, and come apart over time and with movement.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #4 of 4 Old 06-01-2011, 07:27 AM - Thread Starter
LithOTA's Avatar
Thanks guys. Peter will be very happy to hear that.
LithOTA is offline
Reply HDTV Technical
