Persistent shadow/dark spot on Vizio M420NV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-12-2011, 04:55 PM - Thread Starter
Dragonsnack's Avatar
Hello. I'm hoping to take advantage of the collective wisdom of all of the AVS gurus here. We recently purchased a refurbished Vizio M420NV RazerLED 42" LED HDTV from Overstock.com. We've noticed there is a persistent "shadow" at the top of the screen, as if one more of the leds in that area are not illuminating. I've posted pictures and have marked the area with a red circle outline. It is very distracting and we're wondering what the cause may be and if there is a fix for it. I've read that bright and dark spots can be a common occurance with LCDs and LEDs but this seems a bit more extreme. I also own a Panasonic Viera TC-3200LX and have never had an issue with dark or bright spots with it so I'm thinking it is just this particular TV.
Any help/suggestions is greatly appreciated!
I have more and higher resolution pictures HERE.
Dragonsnack is offline
post #2 of 2 Old 06-14-2011, 07:04 PM - Thread Starter
Anybody? Maybe I have this in the wrong forum?
Reply HDTV Technical
Vizio M420nv 42 Inch Class Edge Lit Razor Led Lcd Hdtv
