Possessed new Samsung 55 6050 LED - Comcast, Cables, HDMI, What can it be? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-14-2011, 04:55 PM - Thread Starter
muslenutz's Avatar
So after purchasing a new samsung tv and hooking up the scientific atlanta comcast cable box through the first HDMI port, I noticed some green flashing pixels after a few weeks. Those green flashing pixels have now turned into what you see on picture #1. The strange thing is, if you switch the port to the third HDMI port you get whats on picture #2. My xbox 360 works fine hooked up into all 4 port using HDMI. The cable box works fine on HDMI ports #2 & #4. HDMI #1 and #3 are the ones that seem messed up. I have many wires in back of the tv and if you move them, the lines do move on the tv making me think its interference.
Im so confused, I have tried 3 different HDMI cables - still the same result. Im going to try a new cable box but I have a feeling it is going to give me the same results. I have read many weird things about HDMI, Im just not sure wether its the TV or not.
Has anyone seen anything like this?
muslenutz is offline
post #2 of 8 Old 08-15-2011, 02:58 PM
walford's Avatar
Certainly if you have large gauge(thiner) HDMI cables with low insulation you can get interferance if the HDMI cables are running alongside and close to power cables.
walford is offline
post #3 of 8 Old 08-15-2011, 04:23 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
If a poor quality HDMI cable was the problem, why would it only be a problem on ports 1 and 3, not 2 and 4?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #4 of 8 Old 08-15-2011, 06:39 PM - Thread Starter
muslenutz's Avatar
Got a new cable box, problem seemed to be fixed but now the picture shakes and jitters up and down slightly. I dont know what to think, is it possible that I have another faulty box?
post #5 of 8 Old 08-16-2011, 04:53 AM
Ratman's Avatar
Liked: 1191
Try a hard power cycle of the TV. Unplug from wall power for 5 or 10 minutes.
Ratman is offline
post #6 of 8 Old 08-17-2011, 09:46 PM - Thread Starter
muslenutz's Avatar
Turned out my box was set to only 1080i, I added 780P in the settings and everything is ok so far. Screw Comcast!
post #7 of 8 Old 08-18-2011, 04:32 AM
Ken H's Avatar
Uh, that's most likely not a Comcast issue. That's a Samsung issue if the set can't accept 1080i, which would typically be your best choice for HDTV viewing on a 1080p set.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #8 of 8 Old 08-21-2011, 05:45 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
Your TV is on it's side??
1. Try a direct RF connection to the internal tuner (which you should have anyway),
2. Try a component input.
3. As suggested, try another output resolution.
That's why I don't rent MSO STB's!
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
Reply HDTV Technical
