CM4228 + CM7777+ Eagle Aspen ROTR100 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-24-2011, 06:47 PM - Thread Starter
J_ph's Avatar
I currently have a CM4228 + CM7777, and depending upon the season it seems that I need to move the antenna around because of bouncing off trees etc. So.... I've ordered an Eagle Aspen ROTR100 rotator that uses the existing coax.
It seems that the controller for the rotator replaces the power supply for the CM7777 is that correct? The installation pdf that I downloaded is a little unclear.
thanks in advance for your help.
j
J_ph is offline
post #2 of 6 Old 10-25-2011, 05:39 AM
ProjectSHO89's Avatar
Quoted: 210 Post(s)
Liked: 110
Don't be surprised if you find you have to run a separate coaxial cable.
ProjectSHO89 is offline
post #3 of 6 Old 10-25-2011, 05:43 AM - Thread Starter
J_ph's Avatar
after a little investigation it appears that the CM7777 preamp may not be compatible with the one wire scenario, so you may be right..... or I return it.
thanks
j
J_ph is offline
post #4 of 6 Old 10-25-2011, 05:45 AM
Quoted: 210 Post(s)
Liked: 110
The installation pdf also tells you to call PBI to find out what pre-amps are known to be compatible with the 1-wire system.
post #5 of 6 Old 10-25-2011, 05:53 AM - Thread Starter
J_ph's Avatar
thanks! I missed the note.
the instruction manual states - "+17 VDC at less than 50mA power"
the product PDF states - "18VDC at up to 80 ma"
http://www.eagleaspen.com/admin/prod...n/file_251.pdf
http://www.antennasdirect.com/cmss_f...%20-%20PBI.pdf
I think it may be worth a call.....
J_ph is offline
post #6 of 6 Old 10-25-2011, 05:03 PM - Thread Starter
J_ph's Avatar
I did receive a prompt response from PBI -here's the list of compatible pre-amps:
Channel Master:0064DSB, 0264DSB, 0068DSB or 3010 Stealth active
antenna.(Models 0065DSB and 0265DSB are equivalent to 0064DSB and
0264DSB, but without a power supply included)
From winegard
HDP-269 or the AP-8700. Winegard tested these preamplifiers with this
rotor and had no problem. You will need to keep your downlead to less
than 150 feet of RG6/U cable.
J_ph is offline
Reply HDTV Technical
Channel Master Cm 7777 Titan2 Uhf Vhf Preamplifier Cm7777 , Channel Master Cm 4228 8 Bay Hdtv Uhf Antenna Cm4228hd
