HDMI with removable end, or some other way to get through small opening? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-01-2011, 10:00 AM - Thread Starter
jbsjbs's Avatar
This question seems to get asked every couple of years, so I'm hoping since it was last asked some company has decided to make it happen.
I'm running hdmi through a masonry wall and would love to not have to drill a 1" hole to put it through. It seems this would be a common enough need that someone would have a removable head, but it seems not to be the case.
The best option I can come up with thus far is (and I don't actually know if this would work) running an hdmi to micro-hdmi cable through then converting the micro-hdmi male back to an hdmi male with something like this:
http://www.usbsea.com/products/HDMI_...-AD-HMHF4.html
I'm sure that's not the most elegant solution, but does anyone know whether it would work or if there's a better way to accomplish the same ends?
--Jason
jbsjbs is offline
post #2 of 9 Old 11-01-2011, 10:39 AM - Thread Starter
jbsjbs's Avatar
I suppose one related question, in lieu of a good detachable option, is what are the thinnest (head) hdmi cables people have come across? Most of mine seem to need a hole diameter of at least .81, but my largest masonry bit (at the moment) is 3/4". I can probably grind it out and make it work, but if there's a relatively slim-headed option out there that would be better. Thanks again!
jbsjbs is offline
post #3 of 9 Old 11-01-2011, 12:05 PM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
Here's a recent thread with a similar question:
http://www.avsforum.com/avs-vb/showt...0#post21123960
Or you can just purchase (or rent/borrow) a larger masonry bit.
You can always try to "dress up" the hole using a bushing.
Ratman is online now
post #4 of 9 Old 11-01-2011, 01:17 PM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
Somebody, Calrad?, used to make an HDMI cable with a DIN type conenctor in line for exactly what the OP wanted to do. Not on their WEB site anymore. Perhaps it was not compliant based on the DIN connector and caused too many returns.
Glimmie is offline
post #5 of 9 Old 11-01-2011, 01:36 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
Maybe this?
http://www.rapidrun.com/
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #6 of 9 Old 11-01-2011, 02:00 PM
sitlet's Avatar
The only way I have seen this done is with an HDMI over cat5 extender.
sitlet is offline
post #7 of 9 Old 11-01-2011, 02:03 PM
Ratman's Avatar
Liked: 1022
Yes, that was suggested in the thread I linked to previously.
OTOH, a larger drill bit is less expensive IMO.
post #8 of 9 Old 11-01-2011, 04:00 PM
Ken H's Avatar
Here's a way to terminate an HDMI cable, after it's in place.
http://www.avsforum.com/avs-vb/showthread.php?t=1284801
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #9 of 9 Old 11-01-2011, 05:41 PM
Colm's Avatar
Liked: 94
All the alternatives to making a hole big enough to accept a HDMI plug have significant down sides. IIWY I would buy/borrow/rent whatever is necessary to drill the hole.
Colm is offline
Reply HDTV Technical
