NEW Panasonic TV shuts off after 15 minutes?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-10-2011, 08:31 AM - Thread Starter
destropaul's Avatar
We just installed a Panasonic TCP60ST30 into an existing system with an Integra receiver connected with a 50' HDMI. and an RTI remote system (XP8 processor).
Everything was working fine for weeks, now the TV shuts off after 15 minutes on any source. We thought it was a bad TV so we changed that out... it still does it. The TV just turns off, no indicator lights flash, just off.
All signal settings/sleep timers/etc are turned off on the TV. It's either: the Power, the HDMI wire, the receiver, the RTI system.... or?
Any thoughts?
destropaul is offline
post #2 of 6 Old 12-10-2011, 08:54 AM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
Have you connected any device directly to the TV?
(temporary hookup of DVD, BD, VCR, Coax, etc)
Using the composite, component, tuner, HDMI inputs on the TV itself.
You have to divide and conquer when troubleshooting.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is online now
post #3 of 6 Old 12-10-2011, 09:03 AM
arxaw's Avatar
Probably not the cause, but check the energy saving features, if any, in the TV's menu. And as zaphod said, disconnect any peripheral devices and see if it still occurs (use antenna or straight cable for a source). If the problem disappears, reconnect devices, one by one until the problem returns.
arxaw is offline
post #4 of 6 Old 12-10-2011, 11:32 AM
Ken H's Avatar
Turn Viera Link off.
It sends and receives info via HDMI, including auto power on/off commands from other devices that are in a similar mode.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #5 of 6 Old 12-10-2011, 02:55 PM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
Actually, the idea (which I might not have explained well enough) was to use a short, direct connection of a video device since it seemed that he was using the Receiver as his video switch and relying on the single, 50', HDMI cable to feed signals to the TV from all sources. (not an unusual method for wall-mounted sets or large media rooms)
And repeating Ken's advice to turn off the Viera Link
post #6 of 6 Old 12-11-2011, 08:39 PM - Thread Starter
destropaul's Avatar
It turns out that the RTI XP8 is sending out the power off command just to the TV, weird.. . not sure why it would be doing this after 15 minutes, everything worked fine for a month. I'll have to scratch through programming to see if there are any strange flags/etc... or any thoughts on that?
Reply HDTV Technical
