Long Sattelite run need tips for Cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-05-2012, 10:00 PM - Thread Starter
Slash's Avatar
I will be installing a DIRECTV sattelite dish on my shop which will require an across the roof, down the wall then direct burial run to the house of approx 175'. Once it reaches the house, it will be split into two runs: 50' to 1 receiver and 80' to the other.
I am guessing that the 175' outside/direct burial should be RG11, and the runs inside the house should be RG6.
All discussions that I've seen regarding RG11 relate to OTA... I am assuming that the sattelite would have the same requirements.
The other thing that is boggling my mind is how to select a brand/model of cable... There are so many and the price fluctuations are astronomical.
I have two questions:
1) Am I correct with my assumptions regarding the cabling requirements (i.e RG11 & RG6)?
2) Can you provide links to a brand/vendor of a well priced cable that would be suitable quality for my application
Thanks in advance for any advice
Steve Russell
Slash is offline
post #2 of 5 Old 01-06-2012, 03:33 AM
Scooper's Avatar
I'm not sure if DirectTv can go that far (even with the RG11) - and even with Dish using Dishpro - I wouldn't want to exceed 150 feet total from LNB to farthest receiver. Maybe one of the installers will chime in if your plan will work or not.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #3 of 5 Old 01-06-2012, 05:50 AM
AntAltMike's Avatar
Quoted: 130 Post(s)
Liked: 62
I'd never use RG-11 over those lengths... and I keep a roll of it on the truck.
You have a so-called "loss budget" of about 30dB, and you lose about 8dB per 100 feet of RG-11 and about 4 to 5dB through the splitter. You should use copper center conductor RG-6 to minimize the DC voltage loss.
If you want to have some people furnish you with more detailed signal loss information, you can start a thread at DBSForums, which is affiliated with this forum.
http://www.dbstalk.com/forumdisplay.php?f=113
AntAltMike is offline
post #4 of 5 Old 01-07-2012, 08:17 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
I think the main concern with long distances is voltage drop, not signal loss. The Series 11 cable will compensate for both of those, especially if it's solid copper center conductor. Just make sure you're using a PI-21 power supply.
CIAO!
Ed N.
egnlsn is offline
post #5 of 5 Old 01-08-2012, 08:56 AM
kenglish's Avatar
Liked: 39
Stick with well-known brands of cable, like Belden or TFC.
As for the length, maybe you could try running about 50-100 feet more than you'll need, of RG-6/U, right across the yard and see how it works for a day or two. If that works (with the little bit of extra cable length), then the RG-6/U should be OK). Then you can run it all neatly.
I've run older dishes at work over 200 feet, even with copper-clad steel center (which is supposed to have a larger voltage drop).
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
Reply HDTV Technical
