Combine UHF / FM with cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-08-2012, 05:03 PM - Thread Starter
BSTNFAN's Avatar
Quoted: 21 Post(s)
Liked: 34
I would like to mux the signals from UHF and FM antennae into the Comcast signal and then split them on the other end. Is that possible? Will my DCX series unit be able to function completely? Anything special I should know?
BSTNFAN is offline
post #2 of 9 Old 01-08-2012, 05:15 PM
Ken H's Avatar
No it's not possible. Use a separate cable for the UHF & FM feed.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 9 Old 01-08-2012, 05:20 PM - Thread Starter
BSTNFAN's Avatar
Quoted: 21 Post(s)
Liked: 34
Was definitely my preference, but I'm hitting cabling difficulties.
BSTNFAN is offline
post #4 of 9 Old 01-08-2012, 05:32 PM
Ken H's Avatar
Posts split off and moved to new topic.
Ken H is offline
post #5 of 9 Old 01-08-2012, 07:15 PM
Tschmidt's Avatar
Not possible as they both use the same frequencies. Need to run separate Cables.
Tschmidt is offline
post #6 of 9 Old 01-09-2012, 05:12 AM
Scooper's Avatar
BSTNFAN - you have a choice - run the separate cable or do without.
As stated above - cable and the channels you want share the same frequenies. The cable company will certainly have heartburn with your plan.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #7 of 9 Old 01-09-2012, 07:02 AM
kenglish's Avatar
Liked: 39
You'd have to build a Cable TV headend, and shift the signals to L-Band, then back down again. It would cost lots more money than running a second line.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #8 of 9 Old 01-09-2012, 10:57 AM - Thread Starter
BSTNFAN's Avatar
Quoted: 21 Post(s)
Liked: 34
Thank you everyone for the replies. I am having frustrating difficulties running a new line which is why I was hoping (grasping) for a reasonable alternative. Looks like I need to come up with a plan C.
BSTNFAN is offline
post #9 of 9 Old 01-09-2012, 12:50 PM
kenglish's Avatar
Liked: 39
Explain what the difficulties are, and someone here can probably help you. We all have certain tricks we've learned. Also, those big-box home stores have plenty of the tools available....much more so that in years past.
kenglish is offline
Reply HDTV Technical
