2port HDMI Switch V.1.3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-09-2012, 11:32 AM - Thread Starter
norbiux's Avatar
I both a 2 port HDMI Switch V.1.3 and connected my Xbox and Satellite to it.The problem is when i turn off my xbox my Satellite stops working the TV displays "mode not supported" when the xbox is on it works fine.Any idea what could be the problem? If i only have the Satellite connected to the switch it doesn't work, but if i use a direct cable it works fine.
norbiux is offline
Reply HDTV Technical
