300 ohm twinlead to Coax? - AVS Forum | Home Theater Discussions And Reviews
Old 01-18-2012, 11:02 AM - Thread Starter
Norsican's Avatar
Just remembered....I have a huge Antenna ( dont ask me the brand) that is akin to something like This hanging in the darkest reaches of the attic from the previous owner with what I remember was Flat wire.
This is an older antenna prior to everything going Digital.
1) Will it still work?
2) Is there such a thing as an adapter that will take flat wire to Coax?
THERE IS NO NORSICAN, THERE IS ONLY ZUUL
Norsican is offline
Old 01-18-2012, 11:21 AM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
http://www.amazon.com/300-Ohm-UHF-Ma.../dp/B0002ZPIOG
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
Old 01-18-2012, 11:22 AM
kenglish's Avatar
Liked: 39
You should have clicked the little "accessories" icon on that same Radio Shack page.....you need the "Matching Transformer" (which hooks to the antenna itself), and coaxial cable (to go from the transformer, all the way to the TV).
If there's already flat lead (300-ohm twinlead), just replace it. Twinlead is too much trouble to mess with any more, although it CAN be a little bit less loss....if you put it in exactly the right way.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
Old 01-18-2012, 12:28 PM - Thread Starter
Norsican's Avatar
Ha!....
So I would jsut attach those at the Antenna and run Coax from there...nice.
Thanks agains folks!
Norsican is offline
Old 01-18-2012, 05:58 PM
arxaw's Avatar
Yes, connect the balun (transformer) at the antenna terminals (where the flat wire is connected) and just screw on the coax.
Be sure and buy RG6, not the cheaper, but similar looking RG59 sometimes sold at big box or discount stores. Look on the packaging or on the info stamped into the side of the coax. RG6 has less loss than RG59.
Any TV antenna will work for you, if it is suitable for your distance from the towers and the channel bands/frequencies being used in your area. There's no such thing as a "digital" or "HDTV" antenna. That's just marketing BS to confuse the buyer into thinking they need something new to get DTV.
arxaw is offline
Old 01-20-2012, 04:49 AM
mikepier's Avatar
Quoted: 16 Post(s)
If you don't feel like re-running the twin lead, and if the twin lead is already at the TV, you might want to try this:
http://www.radioshack.com/product/in...ductId=2062054
Connect the twin lead to this transformer, and just plug the transformer in the back of the TV's antenna input.
If you need to extend the twin lead, then you also need an f-coupler, or barrel splice like this to extend the rest of the way from the transformer to the TV with coax.
http://www.radioshack.com/product/in...ductId=2103648
This is just a suggestion, as you might be fine with what you have. But this is assuming the twin lead is in good shape and not cut anywhere. Otherwise as others have suggested, running new RG6 is recommended.
Save your receipts from Radio Shack in case something does not work.
mikepier is offline
