Time Warner Cable Service Menu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-22-2012, 10:21 PM - Thread Starter
SD Vidiot's Avatar
How do I access the service menu on my TWC cable boxes (4250 and 8300) to evaluate signal strength? Many old forums discuss holding down the select button until the "mail" light comes on, then press the "info" button. The "mail" light flashes but nothing happens when I press the "info" button. Is there a newer way I can get to these menus?
Howard
HB
Bear's Lair Home Theater
Howie: "I think my screen may be TOO big."
Norm: "Screens are like breast implants..."
SD Vidiot is offline
post #2 of 2 Old 01-23-2012, 08:45 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 103
For NYC TWC and my 8300HD, believe the diagnostic menus pop up by pressing the 'down' button (just below Select) while the 'mail' light is flashing. Might work there, too. -- John
John Mason is online now
Reply HDTV Technical
