D* HR-24-500 Issue: Pink/magenta line showing at top - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-31-2012, 06:29 AM - Thread Starter
Sirluckyj's Avatar
When the top banner leaves at times I have pink/magenta pixalization show up just at the top of the screen, then leaves. I am using also a DVDO Edge. I bypassed the edge and the issue still happened. My TV is a Pioneer 141 Signature. I know the HR-24 puts out a color space that is RGB (16-235). I have tried verything and cannot get rid of it. This pixalization does not show up when using Blue Ray, etc. Any help would be appreciated. Thanks.
Jim
Sirluckyj is offline
post #2 of 3 Old 01-31-2012, 09:13 AM
Super Moderator
DrDon's Avatar
Quoted: 1273 Post(s)
Liked: 2438
Topic title made more specific, though "line" might be an overstatement..
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #3 of 3 Old 01-31-2012, 03:46 PM
RoyGBiv's Avatar
Quoted: 88 Post(s)
Liked: 37
I have had this since getting the HD GUI. It is on all three of my DVRs, 2 HR20's and 1 HR22. Mine is yellow and white looking like the coding for closed captioning. I believe it only happens on "action" stations, ones which can display sports scores, etc.
I put a message about this on dbstalk. No one responded.
In my case I have found that simply pressing the "exit" button removes it.
SMK
RoyGBiv is offline
Reply HDTV Technical
