Rewired Home with RG6 Cable - Questions about splitting lines - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 02-07-2012, 10:59 AM - Thread Starter
msaggio's Avatar
Hi
I am in the NY/NJ area and my cable provider is Cablevision. I have a few questions about my wiring which I hope someone can help me with.
- I Currently have my trunk line split 4 ways with a 5 - 1000ghz spliter that goes to 2 HD boxes, 1 SD box and 1 Modem. The picture quality on all TVs is great.. Internet speed is ok as well.
- I ran all new lines using RG6 Double Insulated Coax with solid copper center but haven't tied them in yet.
- My new main line/trunk is about 30 feet long and goes into a Leviton 8-Way passive splitter and will split out to 8 different locations. One of these locations being the cable modem.
My questions are..
1 - Should I use a 2-Way splitter before I go into the 8-Way passive splitter to tie the modem in?
2 - If yes, does that need to be a Bi-Directional Splitter?
3 - Should I use a 5 - 2.4ghz or would the 5 - 1000 suffice?
I know that I may either need an amp or to ask Cablevision to turn up the service to allow for the additional lines so I am good on that front.. just want to see if I should split out the cable modem before all of the other SD/HDTV Lines.
Any responses will be appreciated.
msaggio is offline
post #2 of 25 Old 02-07-2012, 01:31 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Originally Posted by msaggio View Post
Hi
My questions are..
1. I'm not sure what your "passive" splitter really is - an 8 output 0dB gain distribution amplifier, or a simple 1->8 splitter. If it is a DA, chances are it is one-way, so the modem should be split off first. If it is a simple splitter, then it has 9.5dB-12dB insertion loss, so the modem should be split-off first. In either event, split the modem first.
2. All 1->2 splitters that i've seen are bi-directional. Some are DC blocking, and some are DC passing, but they are all bi-directional.
3. A 1GHz splitter is fine for now. I wouldn't even consider a 2GHz splitter unless your cable system uses the 840MHz-1GHz bandwidth. Most don't.
domino92024 is offline
post #3 of 25 Old 02-08-2012, 07:54 AM
egnlsn's Avatar
Quoted: 148 Post(s)
Liked: 66
Passive is the only kind of splitter there is. Many manufacturers make an amplifier that has a splitter on the output. Somebody coined the term "active splitter" for marketing purposes, and the term took off. What is often called an "active splitter" is merely an amp with a passive splitter on the output.
CIAO!
Ed N.
egnlsn is offline
post #4 of 25 Old 02-08-2012, 12:24 PM - Thread Starter
msaggio's Avatar
Thanks.. you guys rock!
msaggio is offline
post #5 of 25 Old 02-08-2012, 01:27 PM
Quoted: 126 Post(s)
Liked: 216
Well, no. A splitter can be DC passive, or be DC blocking. DC blocking is not passive at all.
post #6 of 25 Old 02-08-2012, 01:37 PM
Scooper's Avatar
Everything I've read (and the way mine is hooked up) says your cable modem should be on the first splitter coming into the house, with all the TV signals on the other side. At the very least - any / all splitters to the cable modem (and probably your cable boxes) need to be bi-directional.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #7 of 25 Old 02-08-2012, 05:42 PM
egnlsn's Avatar
Quoted: 148 Post(s)
Liked: 66
Splitters are passive in reference to whatever bandwidth they are designed for. Most splitters used in the CATV industry have a bandwidth of 5-1000MHz, yet do not pass D.C.
Whether it passes D.C. or not is a totally separate thing from its passing of R.F.
CIAO!
Ed N.
egnlsn is offline
post #8 of 25 Old 02-08-2012, 06:43 PM
AntAltMike's Avatar
Quoted: 138 Post(s)
Liked: 63
Unfortunately, too many people in this industry use the term, "power passive" when they should be using "power passing".
... which doesn't irk me as much as hearing bar owners refer to their "on-premises" liquor license as an "on premise" license.
AntAltMike is offline
post #9 of 25 Old 02-08-2012, 10:38 PM
Quoted: 126 Post(s)
Liked: 216
...And the sun rises in the east, water runs downhill...
LOL.
post #10 of 25 Old 02-09-2012, 03:28 AM
mikepier's Avatar
Quoted: 16 Post(s)
Hi
If possible, run a second coax to each location so you can have OTA broadcast with an antenna as a backup. These coaxes would plug into the ANT RF input in back of the TV's.
The other ends would tie into a seperate splitter fed from an antenna.
mikepier is offline
post #11 of 25 Old 02-09-2012, 05:17 AM
gregzoll's Avatar
Liked: 33
Why not do it the simple way, and that is run one run back to a central point, so that if you wish to hook up an antenna, or a combiner, so that you can have both incoming catv & OTA, it makes things simple. No need to over do, or over think things.
Too many people make these situations harder than they actually need to be.
gregzoll is offline
post #12 of 25 Old 02-09-2012, 06:32 AM
Scooper's Avatar
In the situation mike pier was talking about - you WOULD need separate coax feeds for cable and OTA TV.
Scooper is offline
post #13 of 25 Old 02-09-2012, 08:13 AM
gregzoll's Avatar
Liked: 33
No you would not. Home run evverything to a patch panel and go from there, with the proper equipment.
gregzoll is offline
post #14 of 25 Old 02-09-2012, 09:55 AM
Scooper's Avatar
Yes you do - 2 feeds of RG6 to each room from the patch panel. You cannot put cable AND OTA on the same cable at the same time. This is if you want cable AND OTA both available all the time.
If you only need one or the other - then yes, 1 cable would be sufficient.
Scooper is offline
post #15 of 25 Old 02-09-2012, 09:55 AM
mikepier's Avatar
Quoted: 16 Post(s)
If you wanted to dedicate 1 TV to cable, and 1 TV to strictly OTA, then that's fine.
But if you ran 2 seperate coaxes, you have the luxury of having both without having to switch cables around at the patch panel or at the STB/TV.
mikepier is offline
post #16 of 25 Old 02-09-2012, 10:24 AM
gregzoll's Avatar
Liked: 33
You are still going to have to go into the tv settings and switch from CATV to Antenna. Again, with a proper set up, you would handle the switching through the system that feeds all equipment feeds to the tv in that room. So your theory just got thrown out the window.
Again, do it properly and with the right equipment, you can use one coax, or hdmi, or component to feed everything through. So, care to throw anything else out there mikepier.
gregzoll is offline
post #17 of 25 Old 02-09-2012, 11:31 AM
mikepier's Avatar
Quoted: 16 Post(s)
Read the original post. The OP has 3 STB's. Explain to me how your magic switching equipment can switch from cable to OTA if the coax is going into the STB's.
mikepier is offline
post #18 of 25 Old 02-09-2012, 11:37 AM
gregzoll's Avatar
Liked: 33
All set tops in the same closet, utilizing rf remotes to do the backgaul of changing chammels. Switchin equipment also in same closet to do the work of allowing the user to seap between various sources.
Gee, do I have to do all of the thinking for you, or just wanting to see if I actually know more about making this easier than you can.
gregzoll is offline
post #19 of 25 Old 02-09-2012, 11:49 AM
mikepier's Avatar
Quoted: 16 Post(s)
And how would you handle getting the OTA channels without buying 3 seperate ATSC boxes?
mikepier is offline
post #20 of 25 Old 02-09-2012, 12:26 PM
Weags's Avatar
Looks like you stumped him...he obviously knows nothing but he will not admit when he's wrong. I wouldn't even bother getting into it with him, it's a lost cause. A conservative 90% of gregzoll's posts contribute nothing but confusion and disbelief to any thread he takes part in.
To the OP , do yourself a favor and run 2 coax to each outlet as mikepier suggested. Following gregzoll will leave you broke from equipment expenses and frustrated beyond belief.
Weags is offline
post #21 of 25 Old 02-09-2012, 01:10 PM
gregzoll's Avatar
Liked: 33
Again, with the proper switchers. I love when hobbiests can not think out of the box.
gregzoll is offline
post #22 of 25 Old 02-10-2012, 11:43 AM
gbynum's Avatar
Quoted: 36 Post(s)
Greg, with all respect, while there are audio-video hobbyists here (I'm one), this forum is the AV __SCIENCE__ forum, and IN GENERAL we try to apply accepted and proven technologies when helping others.
Note; I am NOT a moderator.
More so here than on some other forums, I try to analyze my responses to be complete, accurate, and polite ... and something that can be implemented by anyone.
Your posts are insightful (that's good) but sometimes, as my mother used to say, your eyes are larger than your stomach. Read the thread to understand the question, cogitate a while, then give a well thought out useful answer.
gbynum is offline
post #23 of 25 Old 02-10-2012, 01:14 PM
Quoted: 126 Post(s)
Liked: 216
...hobbyists....outside the box.
post #24 of 25 Old 02-12-2012, 07:15 AM
kenglish's Avatar
Liked: 40
I would just run two RG-6/U to each location, with one carrying the Cable TV signal and one carrying a split of the OTA signal. The OTA goes in to the TV set, so you can get all of your locals (even the ones that Cable does not carry) and they can also be a "backup", and the TV neds to be set for "Air" or "Antenna" mode. The Cable TV feed goes in to the cable boxes, and they should be feeding video and audio signals to the sets.
If you plan to split the Cable feed, you could use a two-way splitter before the 4-way or 8-way, to feed the internet modem.
The modem and the cable boxes are all likely to be bi-directional, so they all will be calling-out upstream anyway, so not a big deal...if they are on a good line, there should be plenty of power to launch back to the Cable company. The Cable guys just like to keep the path a bit shorter on the internet modem side of things.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #25 of 25 Old 02-12-2012, 08:02 AM
Scooper's Avatar
Sure that scheme will work - if you want to go broke buying 20-30 STBs (for a "typical" TV market), plus the associated modulators.
Much cheaper to run 2 RG6 cables to each location, putting an STB at each TV that needs it for OTA, and using the other cable for "Cable" / satelite programming.
Scooper is offline
Reply HDTV Technical
