Terk FDTVO - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 02-24-2012, 01:05 PM - Thread Starter
esa1178's Avatar
Hi there.
I am have connected my TERK FDTVO antenna directly to my Sony Bravia KDL-32S2000. After doing a search I only get 5 local digital channels. Is there something else I should be doing?
Thanks in advance...
Mark
esa1178 is offline
post #2 of 23 Old 02-24-2012, 01:11 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
start with tvfool.com
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 23 Old 02-24-2012, 01:16 PM - Thread Starter
esa1178's Avatar
Thanks Ratman.
Went there first and that's the information that led me to purchasing the HD antenna.
According to my zip-code there are at least 41 channels available to me. I realize, because of obstructions, weather, distance and topography that not all will actually be available. But I should be getting more than 5.
Mark
esa1178 is offline
post #4 of 23 Old 02-24-2012, 01:50 PM
Otto Pylot's Avatar
Quoted: 1667 Post(s)
Liked: 1042
Originally Posted by esa1178 View Post
Thanks Ratman.
Mark
Is it inside or outside?
Otto Pylot is online now
post #5 of 23 Old 02-24-2012, 02:25 PM - Thread Starter
esa1178's Avatar
Hi Otto;
Outside and next to the SAT dish.
Mark
esa1178 is offline
post #6 of 23 Old 02-24-2012, 03:15 PM
Otto Pylot's Avatar
Liked: 1042
Hi Otto;
Mark
By outside do you mean on the roof or a balcony? Can you move it away from the dish? Maybe there's some interference due to proximity. Have your tried other antennas (Yagi-style for example)? Trees, buildings around you?
post #7 of 23 Old 02-24-2012, 03:26 PM - Thread Starter
esa1178's Avatar
Looks I goofed. Could an admInistrator please move this post to the correct arena?
esa1178 is offline
post #8 of 23 Old 02-24-2012, 03:29 PM - Thread Starter
esa1178's Avatar
On the roof. Will try moving the antenna later. No trees blocking reception.
Mark
esa1178 is offline
post #9 of 23 Old 02-24-2012, 03:49 PM
Otto Pylot's Avatar
Liked: 1042
Mark
Hmmm, you might want to consider another type of antenna with possibly a rotor. Mine is on the roof as well but on a 10' tall mast (which makes it about 30' from ground) held securely in place with 3 sets of guy wires. I get more stations than I care to watch but geography and distance (plus LOS) has a lot do with it.
post #10 of 23 Old 02-24-2012, 05:33 PM - Thread Starter
esa1178's Avatar
Moved it to the top of an used chimney stack (as high as it will go). Still only 5 channels. Should I be getting an HD receiver to pull in the OTA HD signals? Lets make sure I am doing this right. Going through TV menu and auto search for digital channels? What antenna do you have Otto?
Mark
esa1178 is offline
post #11 of 23 Old 02-24-2012, 06:56 PM
Otto Pylot's Avatar
Liked: 1042
Mark
Your tv already has an integrated ATSC tuner (HDTV) so another tuner is not necessary. It may be as simple as elevating your antenna higher than it is now. My antenna is a 25 year old Winegard UHF-VHF antenna with 79 elements. Terks are ok but there are probably better alternatives. You might want to move your antenna around and see if you get more stations. Also, some tv's have better tuners than others so you have to take that into consideration.
post #12 of 23 Old 02-24-2012, 06:57 PM
arxaw's Avatar
If you just post a link to your TVFool report for your address, you'll likely get some suggestions for antennas that may actually work.
You do not need an external OTA digital tuner. Your TV already has one built in. You just need a proper antenna for receiving the channels being used in your area, at your address.
arxaw is offline
post #13 of 23 Old 02-24-2012, 07:36 PM - Thread Starter
esa1178's Avatar
Here is my TVFOOL report:
http://www.tvfool.com/?option=com_wr...0b860f047f2bf4
The Terk FDTVO is an omnidirectional with 360 reception pattern. I'm thinking of putting a pole on the back of house and mounting it. How high above the roof should I go? What do you think of the WINEGARD HD8200U HDTV ANTENNA?
http://www.winegard.com/kbase/upload/HD8200U.pdf
I really appreciate all your help guys!
Mark
esa1178 is offline
post #14 of 23 Old 02-25-2012, 05:00 AM
arxaw's Avatar
Your signals are strong at your location and are possibly overloading the amplifier in that omni antenna you bought. Omnis seldom work well, anyway, except for receiving channels equally poorly in all directions.
IF your channels of interest are those in green and to the South of you (mostly at the top of your TVFool "digital" option), this simple passive antenna aimed to the South, is all you need.
http://www.walmart.com/ip/RCA-Suburb...-Mast/10828410
If you want more than the main network channels to the south, you may need something larger and probably a rotor, too. One of the larger antennas in the Winegard 769 series would be good. http://search.solidsignal.com/?x=0&y=0&q=769
For what you'd gain, it's probably not worth the effort or expense, though.
The Winegard 8200u is ridiculously large, due to the fact it has old-school elements tuned for lowband VHF. Your only lowband VHF chs are:
KCSO
k04QR-D
K14MW-D
If those channels are of no interest to you, I would not even consider that antenna.
arxaw is offline
post #15 of 23 Old 02-25-2012, 07:41 AM - Thread Starter
esa1178's Avatar
Would the HD7697P do?
Mark
esa1178 is offline
post #16 of 23 Old 02-25-2012, 08:36 AM
arxaw's Avatar
Other than the green stations on your TVFool, what in particular are you wanting to receive? The ANT751 alone would get you a lot more than 5 channels the TERK received, assuming your TVFool is for the correct address.
arxaw is offline
post #17 of 23 Old 02-25-2012, 08:54 AM - Thread Starter
esa1178's Avatar
Thank you arxaw.
The following channels are the only ones I am looking to pull in, apart from the local channels of course:
KICU-TV
KPIX-TV
KGO-TV
KOFY-TV
KIXE-TV
KRON-TV
Mark
esa1178 is offline
post #18 of 23 Old 02-25-2012, 09:07 AM
arxaw's Avatar
The 7697 plus a high quality low noise preamp mounted on the mast, would likely get you KICU and KPIX. But, you would also need a rotor to turn the antenna when you wanted to view channels off-axis from your main ones in green.
Forget: KGO-TV KOFY-TV KIXE-TV KRON-TV. Although they appear on the list, their strengths are too weak to be received at your address and antenna height you entered.
So, basically, with a huge 7697 antenna, preamp and rotor, you would probably gain only one or two more channels of interest to you; vs the small ANT751 by itself, which should get at least all your channels in green and probably a few more, if in roughly the same general direction.
arxaw is offline
post #19 of 23 Old 02-25-2012, 09:10 AM - Thread Starter
esa1178's Avatar
KGO-TV KOFY-TV KIXE-TV KRON-TV Are the the only reasons we would want an antenna. So there is nothing out there on the market that would allow me to pull them in? What about moving towards SAT Dish setup?
Mark
esa1178 is offline
post #20 of 23 Old 02-25-2012, 09:49 AM
Otto Pylot's Avatar
Liked: 1042
Thank you arxaw.
KICU-TV
KPIX-TV
KGO-TV
KOFY-TV
KIXE-TV
KRON-TV
Mark
Where are you at? Those are my local stations as well. The closest description of the antenna that I have is the Winegard Chromstar 2000 series, model CA-8100. But like I said, that was purchased over 25 years ago. 42 UHF elements and 37 VHF elements. It is a big beast but has been rock solid for all of those years regardless of environmental conditions. In fact, I have a rotor but have never really needed to use it because
everything I want to watch I can get having it pointed in one direction, including the stations you list. 30' from ground to top of antenna mast is considered a good height for most situations.
Oops. I see you're in Sacramento trying to pull in Bay Area stations. Yeah, you may just be too far away regardless of antenna size.
post #21 of 23 Old 02-25-2012, 09:50 AM - Thread Starter
esa1178's Avatar
Sacramento, CA
Mark
esa1178 is offline
post #22 of 23 Old 02-25-2012, 01:24 PM
Otto Pylot's Avatar
Liked: 1042
95831
Sacramento, CA
Mark
I appended my post but yeah, I saw that. You may be SOL for those stations
post #23 of 23 Old 02-25-2012, 03:01 PM - Thread Starter
esa1178's Avatar
Look's like I might be leaning towards a C-Band setup then...
Thanks a bunch
Mark
esa1178 is offline
Reply HDTV Technical
