Netflix sound problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-04-2012, 12:58 PM - Thread Starter
tankbulldog's Avatar
I have Vizio XTV553sv with Direct tv running through a Denon 2112ci. The problem we are having is when we stream a movie from netflix through the tv apps. we get video but no audio. Does anyone have this problem and have a solution? Thanks
tankbulldog is offline
post #2 of 2 Old 03-04-2012, 01:55 PM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1030
Do you have an audio connection "from" the TV to your audio reveiver (analog or digital)?
Does Netflix streaming audio work with the TV's audio (assuming you're using the APPs in the TV).
If you are using a digital audio connection from the TV to the audio receiver, is the digital audio output set to DD, PCM or both (or auto).
Ratman is online now
Reply HDTV Technical
