cable to HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-08-2012, 09:59 AM - Thread Starter
srmalcomson's Avatar
is there a simple box that i can run my standard cable into and HDMI out of? my tv's cable input is broken, but i have an HDMI port that i could use. i have comcast cable internet and just want the basic channels so i don't use the cable company's box. any converter info would be much appreciated.
srmalcomson is offline
post #2 of 12 Old 03-08-2012, 10:23 AM
McDonoughDawg's Avatar
Quoted: 20 Post(s)
Liked: 31
No, nothing simple for what you need. Not that I know of anyways.
There was a thread on here last few weeks about this.
Peachtree City Golf Cart Rider
McDonoughDawg is offline
post #3 of 12 Old 03-08-2012, 10:24 AM
RadRacer513's Avatar
Someone correct me if I'm wrong, but I think you're looking for a DTV box. You can't just convert the coax signal into HDMI, you have to decrypt the individual channels through a tuner box and then run the output of that to your tv. You'll have to use the tuner box to switch the channel, while leaving your TV set to the HDMI input it's on
RadRacer513 is offline
post #4 of 12 Old 03-08-2012, 11:24 AM
sitlet's Avatar
This... You NEED a cable box, or a tuner for a computer with an hdmi out.
sitlet is offline
post #5 of 12 Old 03-08-2012, 02:40 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Originally Posted by srmalcomson View Post
is there a simple box that i can run my standard cable into and HDMI out of? my tv's cable input is broken, but i have an HDMI port that i could use. i have cable internet (just want the basic channels so i don't use the cable company's box). any converter info would be much appreciated.
You'd need a QAM cable tuner to choose among the hundreds of channels on that cable, then use the HDMI to transport that one channel to your TV. Why not just repair your TV's coaxial input?
domino92024 is offline
post #6 of 12 Old 03-09-2012, 05:19 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
What is it that is "broken"? If it's just the F connector, that's probably simple to fix yourself if you have some basic skills. If not, I'd be willing to bet that the repair by a qualified tech would be inexpensive. Probably less than purchasing an external QAM tuner and IMO more convenient.
Ratman is offline
post #7 of 12 Old 03-09-2012, 02:54 PM
Quoted: 126 Post(s)
Liked: 216
Either repair his coaxial connection, or get a QAM tuner. Not much other assistance is possible.
post #8 of 12 Old 03-10-2012, 06:56 AM - Thread Starter
I use Comcast and do get internet through them. Sounds like a tuner or repair are my options. Thanks to those willing to help!
post #9 of 12 Old 03-10-2012, 09:20 AM
Ratman's Avatar
Liked: 1029
If the "connector" is broken, get an estimate.
Ratman is offline
post #10 of 12 Old 03-10-2012, 11:22 AM
Ken H's Avatar
Yes. The list of stand alone tuners, aka set top boxes (STB) is here: http://www.avsforum.com/avs-vb/showthread.php?t=179095 New units start at less than $130 and used ones can be found on ebay for less than $60, at times.
I'd get a repair estimate and decide which option looks better to you. If the HDTV is newer, less than 3 years old, I'd lean to getting it fixed. If it's older than that, I'd lean to getting a STB.
Picking an STB is not as straight forward as it should be. Each of the units has its own pros and cons. Do your homework before buying and see the linked topics for the currently available units. Be sure the unit you get has both a QAM tuner & ATSC (for use with an antenna). Digital tuners either come ATSC alone or ATSC & QAM.
The older units are cheaper but also have drawbacks, primarily the fact the tuners themselves don't always work as well. Some of the older QAM units don't get all QAM channels the cableco passes, while others don't read PSIP (channel remapping info).
The other option is to rent an HD box for just the local channels from Comcast. In my area it only costs $2.50 a month. Check with them for the cost in your area.
Good luck.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #11 of 12 Old 03-11-2012, 07:51 AM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
In the future (and it may require a minimal Cable subscription) the HD DTAs would be an option. The Motorola HD-DTA100u has RF (ch3/4) and an HDMI output. This is being rolled out and is listed on the latest rate sheet (Comcast) as a $2.50 upgrade for "limited basic" subscribers.
Some of the flat panel TVs have tuners that are very, very difficult to repair and the tuner is usually considered as part of the whole board and is not an available separate part.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is offline
post #12 of 12 Old 03-11-2012, 11:33 AM
Ken H's Avatar
Topic 'cleaned up'.
Ken H is offline
Reply HDTV Technical
