Where can I find a stand alone HDTV tuner for my DLP TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-08-2012, 02:13 PM - Thread Starter
snukax's Avatar
My LG DLP TV was manufactured prior to 2007 so does not have a built in HDTV tuner. It is easy to find a SD digital tuner box and easy to find an HDTV tuner for a computer but I need an HDTV tuner box for my television. Thanks for the help!
snukax is offline
post #2 of 14 Old 03-08-2012, 04:26 PM
rabbit73's Avatar
Quoted: 473 Post(s)
Liked: 198
Welcome to the forum, snukax.
Your will find a list of tuners here:
The Official AVS HDTV STB Synopsis!
www.avsforum.com/avs-vb/showthread.php?t=179095
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #3 of 14 Old 03-08-2012, 05:15 PM
gregzoll's Avatar
Liked: 33
TiVo Series 3 is one. As long as you can get CableCards from your CATV provider, you will have no problem. Or just roll your own like most are doing.
gregzoll is offline
post #4 of 14 Old 03-09-2012, 04:02 PM
pacofortacos's Avatar
Liked: 24
What are you trying to watch, OTA or cable?
pacofortacos is offline
post #5 of 14 Old 03-10-2012, 05:16 AM
RCbridge's Avatar
Quoted: 16 Post(s)
The OTA ones are out there but for cable you should rent.
RCbridge is offline
post #6 of 14 Old 03-10-2012, 07:33 AM
Jack Morris's Avatar
Welcome Snukax!!!
Are we talking about cable or OTA HDTV?
If cable, our local cable company includes 2 free digital HDTV tuners/STBs with each account.
If OTA, there are lots of units to buy such as the DTVPal Plus for around $50.
If you also want a HDTV DVR, there are lots of options for both cable and OTA and some with both cablecard slots and OTA tuners in a single box.
Jack Morris is offline
post #7 of 14 Old 03-11-2012, 07:48 AM
dobyken's Avatar
Originally Posted by Jack Morris View Post
Welcome Snukax!!!
The DTVPal is a SD converter and not a HDTV Tuner. One of the highest rated was the Samsung H260F which you can still find on Ebay. As mentioned ChannelMaster is one of the last companies still making HDTV receivers. I still have an old beast HDTV ready set but went the PC tuner route as it gives you so many more options such as XBMC, MediaPortal or WMC.
Better living through credit cards
dobyken is offline
post #8 of 14 Old 03-11-2012, 10:09 AM
Ken H's Avatar
'Was' is the correct term. The Samsung has been around for a long, long time, and it's performance as a Digital TV tuner has since been surpassed by newer technology. Depending on the location the unit would be used, it may or may not deliver reliable reception.
If you could get one for less than $50 it might be worth a try, but when new units are available starting around $130, I'd consider one of them or other used units that are not quite as old. See the link above for the list.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #9 of 14 Old 03-11-2012, 10:36 AM
Otto Pylot's Avatar
Quoted: 1591 Post(s)
Liked: 997
If you could find an LG LST-3500A or greater that would be an excellent OTA HDTV tuner. I had one for years and it was without a doubt one of the most robust tuners out there for HDTV-ready sets. Wish I could be more helpful and point you to some specific links but I just don't have them anymore.
Otto Pylot is offline
post #10 of 14 Old 03-11-2012, 11:25 AM
Phase700B's Avatar
Liked: 25
The LG is very good as stated, Zenith made one or two also.
Another one is the RCA ATSC 11 or ATSC 21 which has DVI, component, and standard NTSC A/V outputs. . . . and an optical Audio output for passing network Dolby digital 5.1 sound out.
I have one of each, and use just the one for connection to a "no tuner" DVR so I can record HD broadcasts.
Phase700B is offline
post #11 of 14 Old 03-22-2012, 03:48 PM - Thread Starter
snukax's Avatar
Thanks for all of the warm welcomes. I cut the cord and am only interested in OTA. I'm in North Redondo Beach, CA and trying to figure out which antenna is best for my area. I am posing my TVFool link in HDTV technical next.
snukax is offline
post #12 of 14 Old 03-22-2012, 03:51 PM - Thread Starter
snukax's Avatar
I connected a Roku box to this TV which allows access to my PC.
snukax is offline
post #13 of 14 Old 03-22-2012, 03:59 PM - Thread Starter
snukax's Avatar
Is this the RCA unit you are referring to?
http://www.ebay.com/itm/DIRECTV-AM21...item41634720dd
snukax is offline
post #14 of 14 Old 03-22-2012, 04:13 PM
Ken H's Avatar
No, that one is from DirecTV and only works with one of their sat receivers.
Here's the RCA: http://www.amazon.com/RCA-ATSC11-Hig.../dp/B0000BZHAG
Ken H is offline
Reply HDTV Technical
