The Official AVS Nationwide Cable Provider Lists/Maps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 149 Old 03-15-2012, 03:24 PM - Thread Starter
Gt1racer's Avatar
This topic is dedicated to updated Cable Provider maps and lists by state
Stay tuned for your state to be added soon.
for easy access to cable providers serving your area check out
TV Guide
zap2it
Cable Search
Verizon FiOS Availability
Massachusetts
Massachusetts (Click to show)
Xbox Live: gt1racerlHDl
Gt1racer is offline
post #2 of 149 Old 03-15-2012, 03:25 PM - Thread Starter
Gt1racer's Avatar
New Hampshire
New Hampshire (Click to show)
Gt1racer is offline
post #3 of 149 Old 03-15-2012, 04:33 PM
Ken H's Avatar
Topic title edited.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #4 of 149 Old 03-15-2012, 11:36 PM - Thread Starter
Gt1racer's Avatar
Maine
Update 1
Maine Update 1 (Click to show)
Gt1racer is offline
post #5 of 149 Old 03-16-2012, 08:37 AM
dattier's Avatar
Quoted: 153 Post(s)
Liked: 62
This reminds me: years ago I found a map on the net of the boundaries among the five cable areas that the city of Chicago is divided into, but I failed to bookmark it and could never locate it again.  As all five areas are served by Comcast now, and the maps posted here so far appear to mark only county lines, I don't expect any Illinois maps that come to this thread in the future to show the intra-city divisions, but they do matter because Comcast's channel assignments and some other things do differ within the city.
Would anyone know where to find such a map now?  My web searches have been fruitless, but I'm notoriously bad at finding things on the net.
dattier is offline
post #6 of 149 Old 03-16-2012, 09:22 AM - Thread Starter
Gt1racer's Avatar
Originally Posted by dattier View Post
This reminds me: years ago I found a map on the net of the boundaries among the five cable areas that the city of Chicago is divided into, but I failed to bookmark it and could never locate it again.* As all five areas are served by Comcast now, and the maps posted here so far appear to mark only county lines, I don't expect any Illinois maps that come to this thread in the future to show the intra-city divisions, but they do matter because Comcast's channel assignments and some other things do differ within the city.
Would anyone know where to find such a map now?* My web searches have been fruitless, but I'm notoriously bad at finding things on the net.
I'll look into it right now
Edit: is this the map?
Gt1racer is offline
post #7 of 149 Old 03-16-2012, 09:52 AM
dattier's Avatar
Quoted: 153 Post(s)
Liked: 62
Thank you, but no, it isn't (and it doesn't look at all accurate).
Please, there's no rush, and you're taking on a big project as it is, so my question was more for the readership at large than an additional task for you.
dattier is offline
post #8 of 149 Old 03-16-2012, 10:00 AM - Thread Starter
Gt1racer's Avatar
it's totally no problem i will try to find the correct map.
Gt1racer is offline
post #9 of 149 Old 03-16-2012, 02:36 PM - Thread Starter
Gt1racer's Avatar
Chicago Comcast Divisions (1,4,5) and (2&3)
Gt1racer is offline
post #10 of 149 Old 03-16-2012, 03:57 PM
dattier's Avatar
Quoted: 153 Post(s)
Liked: 62
Thank you!  May I ask where you found it?
Some of the north lakefront (those division lines appear to follow the city's semi-official neighborhood boundaries) probably should be red for area 1 rather than blue for area 2 or 3, but the rest looks right.
dattier is offline
post #11 of 149 Old 03-16-2012, 07:24 PM - Thread Starter
Gt1racer's Avatar
Thank you!* May I ask where you found it?
i made the edit, i found it on wikipedia searching Community Areas in Chicago and went off all the zip codes for each area to complete the map via Wikipedia and found the cable listings on zap2it which may have led to the lakefront color error
glad i can help!
Gt1racer is offline
post #12 of 149 Old 03-16-2012, 07:35 PM
dattier's Avatar
Quoted: 153 Post(s)
Liked: 62
Hmm; I don't see anything about it on that Wikipedia page, but maybe it was linked off one of the external links in the footnotes.
The divisions on that page have their own errors, for that matter.
On the other hand, the map you posted might be right; for all I know, after areas 1 and 2 had come under the same provider, Comcast (or AT&T before them) could have cut some of the neighborhoods that were in 1 over to 2.  I can't imagine why, but it's not impossible.
dattier is offline
post #13 of 149 Old 03-16-2012, 10:22 PM - Thread Starter
Gt1racer's Avatar
On the other hand, the map you posted might be right; for all I know, after areas 1 and 2 had come under the same provider, Comcast (or AT&T before them) could have cut some of the neighborhoods that were in 1 over to 2.* I can't imagine why, but it's not impossible.
i basically typed in each of those area's zip codes on to zap2it's tv listings database which came out to what areas had either District 1,3,5 or 2&3 so yes i would agree with you some of the neighborhoods may have switched to a different district entirely.
Gt1racer is offline
post #14 of 149 Old 03-17-2012, 06:57 PM - Thread Starter
Gt1racer's Avatar
Maine update 2
Maine Update 2 (Click to show)
Gt1racer is offline
post #15 of 149 Old 03-18-2012, 10:49 AM
dattier's Avatar
Quoted: 153 Post(s)
Liked: 62
Thank you for the resource; I guess TitanTV would provide the same information.
The cable district boundaries inside Chicago never followed zip code lines, so for every zip (including my own) that straddles the 1-4-5/2-3 boundary, Zap2It lists both selections without giving any clue about how the line snakes through the zip code.
dattier is offline
post #16 of 149 Old 03-18-2012, 04:33 PM - Thread Starter
Gt1racer's Avatar
Maine Update 3: Completed
Maine Update 3 (Click to show)
Gt1racer is offline
post #17 of 149 Old 03-18-2012, 04:49 PM
Keenan's Avatar
Quoted: 2523 Post(s)
Liked: 2376
I appreciate what you're doing here, it seems like quite an undertaking, thank you!
Keenan is offline
post #18 of 149 Old 03-18-2012, 06:57 PM - Thread Starter
Gt1racer's Avatar
No problem i am glad i could help in any way, i'm almost done with Maine and the next state i will be doing is Delaware.
Gt1racer is offline
post #19 of 149 Old 03-18-2012, 07:39 PM
Ken H's Avatar
Please note this topic is a work in progress, and the topic will be pruned and developed over time.
Ken H is offline
post #20 of 149 Old 03-18-2012, 08:59 PM
dattier's Avatar
Quoted: 153 Post(s)
Liked: 62
I came across these maps for the city of Chicago, which appear to be based on accurate data, but the roads and such superimposed on them appear to be off position, so they don't give the boundaries as precisely as the map I saw years ago.
Area 1
Area 2
Area 3
Area 4
Area 5
Rather odd that Area 3 is called "Southwest" while Area 4 to the southeast of it is called "Central."
dattier is offline
post #21 of 149 Old 03-18-2012, 09:10 PM - Thread Starter
Gt1racer's Avatar
Delaware & Hawaii
Delaware & Hawaii (Click to show)
Gt1racer is offline
post #22 of 149 Old 03-19-2012, 07:31 AM - Thread Starter
Gt1racer's Avatar
Rhode Island
Rhode Island (Click to show)
Gt1racer is offline
post #23 of 149 Old 03-19-2012, 06:17 PM - Thread Starter
Gt1racer's Avatar
Connecticut
Update 1
Connecticut (Click to show)
Gt1racer is offline
post #24 of 149 Old 03-19-2012, 09:35 PM
agus0103's Avatar
Quoted: 13 Post(s)
Liked: 25
If the ZIP code search on Zap2it is really what's being used to make these maps, I would consider instead using the FCC database of cable companies in the United States available here. All you have to do is select a state from the drop-down list on the left and hit "execute" to get a list showing the counties and communities in which cable companies in that state are licensed to operate. I would think this method would be less tedious and faster than the Zap2it method, but maybe not.
agus0103 is offline
post #25 of 149 Old 03-19-2012, 09:40 PM - Thread Starter
Gt1racer's Avatar
i'll use both for the project agus thanks for the resource!
Gt1racer is offline
post #26 of 149 Old 03-19-2012, 10:19 PM
agus0103's Avatar
Quoted: 13 Post(s)
Liked: 25
No problem. I wish you well with this enormous project!
agus0103 is offline
post #27 of 149 Old 03-20-2012, 08:08 AM - Thread Starter
Gt1racer's Avatar
Connecticut
Update 2
Connecticut Update 2 (Click to show)
Gt1racer is offline
post #28 of 149 Old 03-20-2012, 02:39 PM - Thread Starter
Gt1racer's Avatar
Vermont
Vermont (Click to show)
Gt1racer is offline
post #29 of 149 Old 03-20-2012, 09:53 PM - Thread Starter
Gt1racer's Avatar
Arizona
Update 1
Arizona Update 1 (Click to show)
Gt1racer is offline
post #30 of 149 Old 03-21-2012, 01:07 PM - Thread Starter
Gt1racer's Avatar
Arizona
Update 2
Arizona Update 2 (Click to show)
Gt1racer is offline
Reply HDTV Technical
