Need a small Charter cable box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-18-2012, 10:14 PM - Thread Starter
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
So, I have a tv mounted above my closet in my bedroom and only have a coax ran to it. Recently, I've been thinking that it would be nice to have premium channels if at all possible.... So, what I'm needing is a box that is small because I don't have any shelves for it, I was hoping to possibly Velcro it to the back of my 32" tv. Does anyone have any suggestions? Does charter offer any small boxes ? Thanks!
MY NAME IS SUE!!! HOW DO YOU DO!!!
"I started out with nothing, and I still have most of it."
dasanii19 is offline
post #2 of 8 Old 03-18-2012, 10:19 PM
Ken H's Avatar
The only place you can get an cable box (HD or SD) is from the cableco. One exception is a TiVo with a CableCARD to rent from Charter, but they aren't small.
If you only want SD, they may have a smaller box, but it varies by location. Call them or better yet stop by one of their offices.
Another suggestion is to mount it in a closet and get an IR extender for the remote. Yes, you have to run cables from the box location to the HDTV.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 8 Old 03-19-2012, 12:59 AM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
Charter does have a smaller size HD cable box that can be connected via HDMI. I have enquired about it myself. But you have to specify you want the smaller size box, and they may have to order one for you based upon availability.
tylerSC is offline
post #4 of 8 Old 03-19-2012, 11:05 AM - Thread Starter
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
Would you happen to know the model #?
post #5 of 8 Old 03-19-2012, 11:14 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Are you looking for an HD box?
RCbridge is offline
post #6 of 8 Old 03-19-2012, 12:49 PM - Thread Starter
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
Anything small enough, HD would be better though.
post #7 of 8 Old 03-19-2012, 04:29 PM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
If you velcro it to the back of the TV how are you going to use the cable box remote. If possible find another location for the cable box and run HDMI from the box to the TV. Monoprice has inexpensive cables that should work.
HDMI Guy is offline
post #8 of 8 Old 03-19-2012, 08:01 PM - Thread Starter
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
Couldn't I use some sort of IR eye? The only other place I could put the box is in the closet, but I would still need some sort of IR. Where can I buy a IF eye at? Alao, can I buy my own cable box or do I need to rent it from charter?
Reply HDTV Technical
