North Redondo Beach - What should I get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-22-2012, 04:54 PM - Thread Starter
snukax's Avatar
Here is my TVFool link:
http://www.tvfool.com/?option=com_wr...0b86c98e18353f
There are hills and a two story building at ~36 degrees. I got the popular/cheap antenna from monoprice - it picks up the UHF but not the vhf channels pretty well. What do you recommend that I get? Do I need any gain? Ideally, I would hook up to my existing coax that feed three tvs. Anybody out there live in Redondo?
snukax is offline
post #2 of 3 Old 03-22-2012, 07:59 PM
arxaw's Avatar
A small ANT 751 should work great. It comes with its own small J-mount bracket. Aim it with a compass at 22° magnetic direction.
arxaw is offline
post #3 of 3 Old 03-23-2012, 09:34 AM - Thread Starter
snukax's Avatar
Ok, I just ordered it on Amazon. Wish me luck.
snukax is offline
Reply HDTV Technical
