DirecTV or Fios? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-28-2012, 11:40 PM - Thread Starter
amazonracer's Avatar
I have a Direct TV guy coming on Saturday to replace my Verizon Fios. Getting a new Sharp 3D 60 inch LED display. Saving money for at least a year and a $150 Best Buy gift card. However, I can't get a handle on the difference in PQ. Some say Fios is far superior and others say the opposite. Also, I do believe the DVR is better on Direct. My main concern though even with saving some money is picture quality. Will I be able to tell? Thanks
amazonracer is offline
post #2 of 7 Old 03-29-2012, 03:47 AM
Jedi Master's Avatar
Quoted: 12 Post(s)
Liked: 31
For your local channels you should hook up an antenna to get your local channels in HD. OTA HD has the best picture quality available.
Broadcast TV - a vital national public resource
Jedi Master is offline
post #3 of 7 Old 03-29-2012, 06:46 AM
adb
adb's Avatar
I don't know of any current Direct TV receivers that have antenna connections
adb is offline
post #4 of 7 Old 03-29-2012, 07:01 AM
ljo000's Avatar
You'd hook the antenna into the TV directly, not through the box.
ljo000 is offline
post #5 of 7 Old 03-29-2012, 07:15 AM
arxaw's Avatar
Some D* DVRs allow connection of an AM21 OTA add-on tuner, which integrates the OTA antenna channels into the guide. Adding OTA antenna channels also increases recording flexibility.
http://www.solidsignal.com/pview.asp?p=AM21
Re picture quality of D* vs OTA; in most cases you will not see a difference in PQ between the two sources. And if a local station has multiple OTA sub-channels, and if they send their feed to D*'s local receive/uplink facility via fiber, the PQ on D* may actually surpass OTA. YMMV.
arxaw is offline
post #6 of 7 Old 03-29-2012, 07:19 AM
Super Moderator
DrDon's Avatar
Quoted: 871 Post(s)
Liked: 1730
Please use specific topic titles. See my edit.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #7 of 7 Old 03-29-2012, 08:10 AM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
Putting the OTA or locals via D* aside, I'd be willing to guess that FiOS would have an edge on PQ for the additional channels.
Let us know what you think after your D* hardware is installed.
Ratman is offline
Reply HDTV Technical
