LG HDTV will not pick QAM channels but other devices will. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-05-2012, 05:13 PM - Thread Starter
puregenius's Avatar
I have a LG HDTV, a cheap AOC envision 19" HDTV and the Magnavox MDR515H. I have digital economy service and high speed internet from Comcast in the San Francisco Bay Area. When I connect coaxial cable to the AOC and MDR515H, I am able to tune to some DTV channels. 5.1 & 11.1 are the ones that work best. When I connect to the LG TV, I get nothing. Whether I channel scan or manually navigate it does not pick up any DTV content whatsoever. Does anyone have an opinion as to the reason for this. The manual for the LG TV says it has a QAM-256 tuner.
puregenius is offline
post #2 of 19 Old 04-06-2012, 10:52 AM
gbynum's Avatar
Quoted: 25 Post(s)
My guess is that you are scanning ATSC (antenna) vs. QAM (cable) channels. If you'd given a model, we could help further.
gbynum is offline
post #3 of 19 Old 04-06-2012, 12:22 PM - Thread Starter
puregenius's Avatar
The model number for the LG TV is 32LH30. THE MDR515H is definitely scanning ATSC, so the TV should at least get the same results right?
post #4 of 19 Old 04-06-2012, 12:54 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
It looks like you don't have to choose between Cable or Antenna when doing the scan, it must just scan whatever is attached?
Possibly your channels are there (were actually found) but are using different channel numbers than your other TV's do. Maybe one of the sets re-assigns the numbers based on PSIP data and the LG doesn't?
Or maybe the LG is broken. Did you buy it new?
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #5 of 19 Old 04-06-2012, 01:59 PM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
That would be my guess. The OP needs to figure out the virtual channel numbers. Might be a good idea to go to the HDTV local forums and find the one that is specific for his area and ask for the channel assignments there. Might be as simple as that.
Otto Pylot is offline
post #6 of 19 Old 04-06-2012, 02:27 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
How is the LG connected? Maybe it's not seeing the raw signal on the coax?
The 515's coax circuit passes the raw signal thru so a TV attached to coax out from the Mag 515 will see that signal and any channels in it.
Maybe bypass other components and run incoming coax only to the LG and scan?
wajo is offline
post #7 of 19 Old 04-06-2012, 02:35 PM
retiredengineer's Avatar
Quoted: 35 Post(s)
Liked: 24
The LG 32LH30 HDTV is a 2009 model. I would return it for a refund, since you must of got a refurbished model that has a broken cable input.
retiredengineer is offline
post #8 of 19 Old 04-06-2012, 06:49 PM - Thread Starter
puregenius's Avatar
I am starting to think it is defective. I bought it new but never attempted to scan for channels. It was always connected to a cable box. Thanks for the thoughts.
post #9 of 19 Old 04-06-2012, 06:55 PM - Thread Starter
puregenius's Avatar
I go from the wall to a splitter and run one line to the 515 and the other to the LG. I decided to remove the splitter and see if going from the wall to the LG would make a difference. It did not. It picks up TV and CATV fine, but no CADTV. I think the QAM tuner is defective.
post #10 of 19 Old 04-07-2012, 10:05 AM
walford's Avatar
Does the TV have one or two coax inputs? If two try the other one since you may be connected to the analog tuner since you are getting analog channels.
walford is offline
post #11 of 19 Old 04-07-2012, 10:41 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
The TV only has one RF input.
Ratman is online now
post #12 of 19 Old 04-07-2012, 01:44 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
Link to the manual-
http://www.lg.com/lgecs.downloadFile...M000224764.pdf
Blu-rays & DVD's
WS65711 is offline
post #13 of 19 Old 04-07-2012, 04:27 PM
Otto Pylot's Avatar
Liked: 852
I hope this is a defective connector and not another owner who didn't RTFM.
post #14 of 19 Old 04-07-2012, 06:17 PM
arxaw's Avatar
@puregenious,
After the scan, did you step through every channel number (using channel UP/DN on the remote), and not just the ones where you expected the channels to be?
arxaw is offline
post #15 of 19 Old 04-07-2012, 07:09 PM
Ratman's Avatar
Liked: 1022
With a defective connector, one would think that the analog cable channels would not work. RTFM is always a good recommendation though. Did you look through it? The link has been provided above.
post #16 of 19 Old 04-08-2012, 11:51 AM
Otto Pylot's Avatar
Liked: 852
True. A defective connector probably wouldn't work period for a digital or analog signal. No, I didn't look thru the manual. I figured the OP would do that because it's his tv, not mine. We both know there are owners who'd rather ask questions first before digging thru the manual. However, if he did check the manual (no mention of that fact), and he still can't figure it out, that's a different matter.
post #17 of 19 Old 04-08-2012, 12:53 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
I looked at the manual (wasn't easy to find) a few days ago before I posted my first response. I found it a bit strange that (apparently) there is no setting in the TV to choose between scanning for OTA or scanning for Cable. But I've never messed with any LG TV's. Just one stinkin' LG refrigerator that we bought 6 years ago... mistake But maybe I missed something in the TV manual about scanning?
Blu-rays & DVD's
WS65711 is offline
post #18 of 19 Old 04-08-2012, 01:52 PM
walford's Avatar
I could not find anything in the manual either which implied that the Tuner(s) should find both the analog, ATSC digital and QAM digital signals. It certainly is strange that the OP is getting SD analog channels like 2 and 4 and is not also getting HD digital channels named 2-1 or 4-1.
walford is offline
post #19 of 19 Old 04-08-2012, 02:48 PM
gbynum's Avatar
Quoted: 25 Post(s)
The linked manual shows, on page 57, that you can display a list of stored channels after scanning; does it show anything?
I'm with the rest ... per the manual, QAM is included in the single scan.
It discusses scan order ... it is not unusual for each of ATSC and QAM scans to take as long as an hour ... by ANY chance, are you interrupting scan after it is partially done ... like maybe it says ATSC scan complete?
gbynum is offline
Reply HDTV Technical
