Looking for HD Tuner with multi-HDMI inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-15-2012, 09:40 PM - Thread Starter
tvromero's Avatar
Hi All,
I am looking for an HD tuner to connect to my projector. The unit needs to have multiple HDMI inputs in addition to taking in S-video, component, composite and up converting them.
I purchased the PrimeDTV PHD-8VX and it did do the job until it died where it stopped putting out a signal on the HDMI out. I am really hoping it is just a lemon but it did come direct from the supplier so not really holding out hope.
What other units are out there that meet my needs?
Tim
tvromero is offline
post #2 of 5 Old 04-15-2012, 11:09 PM
Ken H's Avatar
I don't think one exists.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 5 Old 04-16-2012, 01:50 PM
DAP
DAP's Avatar
Originally Posted by tvromero View Post
Hi All,
Tim
I think the closest you are going to come is a AV receiver + a QAM/ATSC tuner box.
Personally I have more HDMI inputs in my system than I know what to do with. What I want is an ATSC/QAM tuner with multiple coax inputs.
DAP is offline
post #4 of 5 Old 10-05-2012, 11:42 AM
akevit's Avatar
What would you recommend for a QAM/ATSC tuner box?
akevit is offline
post #5 of 5 Old 10-05-2012, 01:24 PM
Ratman's Avatar
Quoted: 1454 Post(s)
Liked: 1155
http://www.avsforum.com/t/179095/the-official-avs-hdtv-stb-synopsis
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Reply HDTV Technical
