Digital lifestyles wt322 wont turn on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-28-2012, 08:03 PM - Thread Starter
bubba4423's Avatar
I have a wt322 lcd monitor...I purchased this from someone and i was told it works great. Unfortunately it does not. When i plug it in, there is a red light that comes on in the front, And then i try to turn it on (pressing the Power button) and i Hear it try to turn on, but nothing. I hear the typical electronic sound you would normally hear when turning on a tv. The Red light fades when clicking the power button then instantly comes back to full red...
What are the possibility of the issue being something simple? Can you give me any input based on what my specific issue is?
Thanks alot
bubba4423 is offline
post #2 of 2 Old 04-28-2012, 08:27 PM
Ken H's Avatar
Thanks alot
Take it back and get your money back.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Reply HDTV Technical
