Providence, RI: What Antenna should I use - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-02-2012, 07:58 AM - Thread Starter
bicho6's Avatar
My house is 3 miles from the transmitters and from what TV Fool is telling me I can pick up everything I want with an indoor settop setup. Judging from the results below will I be able to get away with an settop aentenna and if so does anyone recommend a good low profile unit?
http://www.tvfool.com/?option=com_wr...de650948392b85
Not sure why the image isn't showing, I'm using the correct tags
bicho6 is offline
post #2 of 7 Old 05-02-2012, 08:38 AM
arxaw's Avatar
For your closest stations, you can use most anything that does not have an amplifier, perhaps even just a short piece of wire stuck into the TV's antanna coax port would work. Seriously, I would try a piece of wire first, before buying anything.
Or, this budget antenna should work fine.
http://www.radioshack.com/product/in...ductId=2103077
arxaw is offline
post #3 of 7 Old 05-02-2012, 08:57 AM - Thread Starter
bicho6's Avatar
No kidding, is it because I'm so close to the stations? I dont often look at the back of my TV but I have a panasonic plasma, I hope it has a coax input.
The wire idea, would you recommend a clothes hanger?
bicho6 is offline
post #4 of 7 Old 05-02-2012, 09:21 AM
arxaw's Avatar
Yes. You are practically sitting on top of the stations' transmitters.
A coat hanger wire would be too large diameter. Something smaller gauge would be a better fit. If you have a piece of coax a foot or so long, remove all the shielding and outer insulation and just use the copper wire in the middle. Stick it in the coax port and run a channel scan for digital antenna channels. You may be pleasantly surprised at the results.
arxaw is offline
post #5 of 7 Old 05-02-2012, 09:25 AM - Thread Starter
bicho6's Avatar
Can't wait to give it a shot, thanks
bicho6 is offline
post #6 of 7 Old 05-02-2012, 09:40 AM
Super Moderator
DrDon's Avatar
Quoted: 878 Post(s)
Liked: 1738
Please put a location in the title of all antenna help threads. See my edit.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #7 of 7 Old 05-05-2012, 08:45 AM
RoyGBiv's Avatar
Quoted: 75 Post(s)
Liked: 35
I don't know what your situation is, but if you have a space to put a larger antenna (attic or on the roof), you can not only get all the Providence stations but also all the Boston stations. I am in Pawtucket. I have a RS antenna just lying on the rafters in my attic pointed towards the Needham towers. I get every RI station perfectly and all the Boston stations as well. It just gives you a lot more opportunities to watch what you want.
SMK
RoyGBiv is offline
Reply HDTV Technical
