Apple TV with Mohu Leaf Antenna? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-02-2012, 09:04 AM - Thread Starter
asen's Avatar
Hi I am new to AVS-
I have been running Apple TV for a long time and am finally ditching paying for cable? I just came across this article about the Mohu Leaf, which I have noticed is well received on Amazon. Wondering if other people have used these together in lieu of cable?
I can't seem to post the URLs, will have to post some audio posts first!
asen is offline
post #2 of 6 Old 05-02-2012, 09:47 AM
ADTech's Avatar
Quoted: 133 Post(s)
Liked: 72
There's an existing thread dedicated to the Mohu. Just scroll down a bit and read through it.
Tech support for Antennas Direct
ADTech is offline
post #3 of 6 Old 05-02-2012, 09:48 AM
BCF68's Avatar
you need to post a TVfool report. How can we tell you anything without knowing what reception is like in your area?
Also a Mohu is piece of crap. I can make a better antenna for $5.
BCF68 is offline
post #4 of 6 Old 05-02-2012, 09:50 AM
retiredengineer's Avatar
Quoted: 35 Post(s)
Liked: 24
There is a review of the Mohu Leaf which can be found at:
www.hdtvexpert.com/?p=2053
retiredengineer is offline
post #5 of 6 Old 05-03-2012, 07:43 AM
arxaw's Avatar
Price notwithstanding, the mohu and similar antennas do have their place. But, without a TVFool report, it's impossible to even make a WA guess whether it would be suitable for the OP's channels of interest, or not.
arxaw is offline
post #6 of 6 Old 05-03-2012, 07:50 AM
olyteddy's Avatar
Quoted: 531 Post(s)
Liked: 931
Originally Posted by asen View Post
Hi I am new to AVS-
Isn't the 'Apple TV' a streaming box? Why would you need an antenna?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply HDTV Technical
