Pelham, NH: Antenna help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-05-2012, 09:22 AM - Thread Starter
geot's Avatar
Any help will be appreciated. New to this hope I am doing it correctly. Also has anyone tried the Eagle Aspen Rotor 100. Thinking of using this for my antenna. Going to bypass the power so I do not loose any signal.
see below for link
geot is offline
post #2 of 8 Old 05-05-2012, 10:46 AM
arxaw's Avatar
I am using a similar rotor, which may be a clone of same. No problems, except the need to re-calibrate the aim occasionally.
YMMV
arxaw is offline
post #3 of 8 Old 05-05-2012, 11:00 AM
Super Moderator
DrDon's Avatar
Quoted: 1180 Post(s)
Liked: 2292
http://www.tvfool.com/?option=com_wr...de65b22c0dea56
Welcome to AVS. No, you're not doing it correctly. Do take the time to look at other threads so you'll know some things. Just a few minutes would have told you..
1. We don't accept "generic" thread titles. Every title needs to be specific as possible. See my edit.
2. ALL antenna help threads MUST have a location in the thread title. Again, see my edit
3. We don't allow bumping to get the post count up. Post a bit ly link without the http stuff or just give us your zip code. Or ask a Mod. We can insert the link FOR you. There are ways so you don't have to litter the thread with bumps. Once again, see my edit to your first post. No trouble at all. Happy to do it.
4. Also, "loose" means "not tight." You want your pants loose. You don't want to LOSE signal. Grouchy, today, ain't I?
Please take time and at least minimal effort to look around to see how we do things here. It'll help you in the long run.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #4 of 8 Old 05-05-2012, 03:45 PM
rabbit73's Avatar
Quoted: 473 Post(s)
Liked: 198
TV fool link in post #1 doesn't work because it is broken in the middle (when I tried it), but link in post #3 quote does:
www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3dde65b22c0dea56
What power for what? You're going to bypass the power for the rotor?
What antenna are you going to put on the rotor?
What signals do you want? If you are happy with the signals coming from about 170 degrees, you don't need a rotor. Less things to go wrong in the middle of winter.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #5 of 8 Old 05-05-2012, 03:46 PM
Super Moderator
DrDon's Avatar
Liked: 2292
Thanks, Rabbit
DrDon is offline
post #6 of 8 Old 05-05-2012, 05:00 PM
jimmyv2000's Avatar
When i lived in Salem (next town over) i used a radio shack VU-120 and was very happy with it Got all boston stations ,Plus 2 ri stations and 9 and 11 on VHF from the back side just dandy! the only issue i had there in salem and where i am now In Machester is getting 50
jimmyv2000 is offline
post #7 of 8 Old 05-05-2012, 05:15 PM
Tschmidt's Avatar
I'm in Milford NH so my situation is a little different. I use separate VHF and UHF antennas. That eliminates the need for a rotor other then playing and fine tuning.
9 and 11 on on VHF and the Boston stations are UHF. There are couple of new Binnie stations on VHF low but so far they are no show and from what I have have seen on Cable I'm not all that interested in the programming. I assume they are going to be translators of WYCN and WBIN out of Nashua but I'm just guessing.
Think about what stations you really want to watch and see if you can come up with a way to do it without a rotor.
Tschmidt is offline
post #8 of 8 Old 05-08-2012, 05:30 AM
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
Yes;
http://www.avsforum.com/avs-vb/showthread.php?t=840847
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
Reply HDTV Technical
