I'm looking for a good 15 foot HDMI cable for my Xbox 360 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-06-2012, 04:14 PM - Thread Starter
GAMESHARQ's Avatar
GAMESHARQ is offline
post #2 of 5 Old 05-06-2012, 04:25 PM
gregzoll's Avatar
Liked: 33
Don't use ebay, just get it from monoprice.com and be done with it.
gregzoll is offline
post #3 of 5 Old 05-06-2012, 05:48 PM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
Monoprice...
texasbrit is offline
post #4 of 5 Old 05-06-2012, 05:57 PM
BHNtechXpert's Avatar
There is no length specified in the spec but for Cat 1 HDMI cables try to limit to 15ft or less and for Cat 2 HDMI cables try to limit to 50ft or less.
For more information this is a good resource: http://en.wikipedia.org/wiki/HDMI
~All truth goes through three phases. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as self-evident. - Arthur Schopenhauer ~
BHNtechXpert is offline
post #5 of 5 Old 05-06-2012, 09:53 PM
Colm's Avatar
Liked: 94
A certified high speed cable is all you need. The problem is finding one that is really certified. Trying to do it on eBay is hopeless unless you are buying a known brand (and it isn't counterfeit). Buy from a reliable source, like monoprice, Blue Jeans Cable, or AV Science, and you will be safe. They all have 15' certified high speed HDMI cables that will handle any signal currently supported by the HDMI specification.
Colm is offline
Reply HDTV Technical
