Question about proper grounding of antenna - AVS Forum | Home Theater Discussions And Reviews
Old 05-06-2012, 05:33 PM - Thread Starter
atarinox's Avatar
Hi all,
I just installed an antenna for OTA reception on an old Dish Network mast from a previous tenant. The mast is attached to a steel clothesline pole, and didn't seem to have any additional grounding.
Is the steel clothesline pole enough of a ground itself that I shouldn't worry? Does the coax cable leading into the house need to be grounded as well?
Thanks for the help...
atarinox is offline
Old 05-06-2012, 07:00 PM
BHNtechXpert's Avatar
Originally Posted by atarinox View Post
Hi all,
I would ground the coax just prior to it entering the house if I were you. Be safe...not sorry.
~All truth goes through three phases. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as self-evident. - Arthur Schopenhauer ~
BHNtechXpert is offline
Old 05-06-2012, 10:59 PM
Colm's Avatar
Liked: 94
Both the mast and the cable need to be grounded. The odds are that the metal pole isn't an adequate ground if for no other reason than it probably isn't bonded to the electrical system's grounding electrode. An there are other reasons why it probably isn't an adequate ground. And as previously mentioned, the cable shield needs to be grounded where it enters the house, preferably close to the electrical service entrance.
Colm is offline
Old 05-07-2012, 06:24 PM
ybsane's Avatar
Quoted: 93 Post(s)
Liked: 34
CATV does not have to be grounded per se, it has to be bonded to the electrical system properly per code for potential differences. The Actual cable plant does need to be gounded before and after every active and EOL's, plus bonded to electric and telephone where needed.
All Comments made are my own and not of my employer.
ybsane is offline
Old 05-08-2012, 01:59 PM
Colm's Avatar
Liked: 94
Originally Posted by ybsane View Post
CATV does not have to be grounded per se...
NEC 810.15 Grounding: Mast and metal structures supporting antennas shall be grounded...
Colm is offline
Old 05-08-2012, 02:32 PM
Bob7145's Avatar
Liked: 36
"shall be grounded" It doesn't say they have to use the same ground. There should only be 1 ground for things enetering the house.
Bob7145 is offline
Old 05-08-2012, 03:53 PM
ybsane's Avatar
Quoted: 93 Post(s)
Liked: 34
Don't quote the code unless you understand it...
When an electrode such as a ground rod is installed to ground the mast or lead-in cable, it must be bonded with a 6 AWG copper conductor to the grounding electrode system at the building or structure served [810.21(J)].
You cannot use a metal rod driven into the earth for grounding of the lead-in cable, unless the metal rod is bonded with a 6 AWG conductor to the building grounding electrode system in accordance with 810.21(J). In addition, the NEC does not allow you to use the local water pipe [810.21(F)(1)(b)
ybsane is offline
Old 05-08-2012, 05:02 PM
arxaw's Avatar
Hi all,
Is the steel clothesline pole enough of a ground itself that I shouldn't worry? Does the coax cable leading into the house need to be grounded as well? ...
Both should be grounded. If the ground is different than the home's main electrical ground, the separate grounds must be bonded together, per posts above.
arxaw is offline
Old 05-08-2012, 07:15 PM
Colm's Avatar
Liked: 94
I understand the code well enough. I suspect you may not understand it as well as you think, though, based on your response to my post. Maybe you ought to follow your own advice.
Colm is offline
Old 05-09-2012, 01:11 PM
ADTech's Avatar
Quoted: 123 Post(s)
Liked: 65
NEC 2008 [810.21(F)(2)(2) states "The grounded metal interior water piping systems, within 1.52 m (5') from its point of entrance to the building, as covered in 250.52"
Which version of NEC are you using as a reference (in case I need to upgrade...)?
Grounding requirements for CATV systems are covered in Section 820. In general, Section 820 also applies to the coaxial cable used in most private antenna systems.
Tech support for Antennas Direct
ADTech is offline
Old 05-09-2012, 01:15 PM
ADTech's Avatar
Quoted: 123 Post(s)
Liked: 65
The quotation given was too short. The rest of it states " in accordance with 810.21" which gets more specific and includes the reference to bonding if separate ground electrodes are used. Bonding the electrodes makes them the "same ground".
ADTech is offline
Old 05-09-2012, 01:47 PM
ybsane's Avatar
Quoted: 93 Post(s)
Liked: 34
Your quoting 2008 and need to upgrade, we always try to be current for all our installers/service techs to be as correct as possible. Too much liability these days.
ybsane is offline
Old 05-09-2012, 05:56 PM
AntAltMike's Avatar
Quoted: 130 Post(s)
Liked: 62
Technically, the most recent revision does not become local "code" until a year or two after its cover date. It only becomes the current code after the legislature or appropriate governing body adopts it.
AntAltMike is offline
