Samsung Update time error - AVS Forum | Home Theater Discussions And Reviews
Old 05-17-2012, 07:57 PM - Thread Starter
Westark9's Avatar
un55d6000sfxza samsung
update time
Your time or date is incorrect, and your network is not connected. Please update the time and date information through the date, time & location settings.
Samsung says it is a AT&T Uverse problem AT&T says it is a Samsung problem! It will not go away have reset tv reset the Uverse just stays in the middle of the screen. Can someone help me please!!!!!
Westark9 is offline
Old 05-17-2012, 09:20 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
U should be able to manually set the time WITHOUT the Internet. If this doesn't work then TV questionable.
MrBobb is offline
Old 05-17-2012, 09:26 PM - Thread Starter
Westark9's Avatar
I have manually rest it and auto reset the time and date! Samsung says that since it is not on all inputs that it. Is AT&T's problem
Westark9 is offline
Old 05-20-2012, 11:34 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Uh? What? Que?
So Samsung is telling you this TV REQUIRES (not an option) for the TV to work. Does that sound right to you?
MrBobb is offline
Old 05-21-2012, 02:09 PM
walford's Avatar
How close to correct is the %TVs time?
Are your time zone and daylight time settings correct?
Is your time being kept on the TV or on the cable Set top Box? normally the cable company keeps the time on the STB since that is where the Guide and PVR scheduling is done from.
walford is offline
Old 05-21-2012, 03:40 PM
Ratman's Avatar
Quoted: 1278 Post(s)
Liked: 1027
Is it a new TV?
Sounds to me like either:
1) TV problem
2) You didn't read the manual or complete the initial (first time) setup.
OTOH...
if you are trying to update the firmware for some reason, your TV's date/time setting in wrong or you don't have an internet/network connection to your TV.
Secondly... is the message generated from the TV or the UVerse box?
More info would be helpful.
Ratman is online now
Old 06-27-2012, 11:45 AM
White67's Avatar
I am having the same exact problem. I can actually watch Uverse through/around the black box giving me the error. But not matter what I do to set up date/time, the black box will not go away! It's not Uverse. The message is not coming from AT&T. Especially since I can watch a TV show around the giant black box. The error message is coming from the TV. I've unplugged the TV. I've turned it on and off. I manually set the date and time numerous times. I've let it auto set date and time. No matter what I do I keep getting the same error messge. Grrrrr:mad:
White67 is offline
Old 06-27-2012, 11:51 AM
Ratman's Avatar
Liked: 1027
Disconnect UVerse equipment from the TV. Hook up a DVD player and/or an antenna. If problem persists, the TV has a problem. CAll Sumsung for service/support (and don't mention UVerse).
If no problem with antenna or DVD player, but only with UVerse... you get the idea.
Old 06-29-2012, 05:30 PM
xt1nct's Avatar
I've got the same error. How do I get rid of this? I have Verizon Fios and I KNOW from testing everything that it not related to the STB. Although I've tried changing every setting there is for the time/date/location and I've even hooked in to the house network thinking this would auto correct and nothing!
xt1nct is offline
