Help me with different refresh rate technologies? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-21-2012, 05:44 AM - Thread Starter
mckevstah's Avatar
I have a Samsung LED tv, that is 120hz. (UE40D5520)
While watching films and sports, I have awesome motion blur that makes it unwatchable most of the time.
I have seen a new TV I would like to purchase.
An LG Cinema 3D 42 inch led. It says it is 100hz TRUMOTION, with 400hz MIC?
Does that mean it will be worse motion blur?
Thank you.
mckevstah is offline
post #2 of 4 Old 05-21-2012, 01:02 PM
walford's Avatar
What setting(s) are you using for Motion Compensation? With a 120Hz unit you should not be having motion blur problems.
walford is offline
post #3 of 4 Old 05-21-2012, 02:02 PM
Otto Pylot's Avatar
Quoted: 1629 Post(s)
Liked: 1024
Thank you.
Sounds like you have the Samsung equivalent of motion interpolation turned on. The LG TruMotion is their version of motion interpolation which artificially adds an extra frame to smooth out the motion but gives it that SOE (Soap Opera Effect) at times depending on how you tweak it. A 120Hz set plays each frame twice (60Hz x 2) so motion should be smoother. I turn off motion interpolation when I watch movies and only sometimes use it for network tv or sports.
Otto Pylot is online now
post #4 of 4 Old 05-21-2012, 10:49 PM
Joe Bloggs's Avatar
Quoted: 440 Post(s)
Liked: 119
Why would playing each frame twice make motion smoother?
Joe Bloggs is offline
Reply HDTV Technical
