Antenna Setup for Washington DC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-29-2012, 12:00 PM - Thread Starter
tsmvengy's Avatar
A friend decided to ditch DirecTV and I suggested that since they have the dish and wiring already set up to the roof that we should stick an antenna up there to see what HDTV she could get.
Location: http://www.tvfool.com/?option=com_wr...073ba26fb80eed
Would something like this or this be a good idea?
tsmvengy is offline
post #2 of 5 Old 05-29-2012, 12:56 PM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
This is by far the best bang for the buck. My next choice would be either the Channel Master you linked to or this. The Clearstream 2 is a UHF antenna & may not work well for 7, 8 & 9.
Digital Rules is offline
post #3 of 5 Old 05-29-2012, 01:44 PM
arxaw's Avatar
+1 on the antenna DigitalRules linked to. If you're not comfortable with craigslist or if n/a, order it from amazon or walmart.
http://www.amazon.com/RCA-ANT751-Out...B5C/ref=sr_1_1
http://www.walmart.com/ip/RCA-Suburb...-Mast/10828410
Aim it compass direction of 325° or roughly NW. If the DirecTV coax cables have any splitters, multiswitch boxes or other equipment in the line, remove any of that, if present (you can reuse the existing ground block). If you need a splitter, use a regular coax splitter from radioshack, walmart, home depot, etc. If you remove a multiswitch and need to splice the cables together, use a barrel splice.
arxaw is offline
post #4 of 5 Old 05-29-2012, 02:43 PM
tylerSC's Avatar
Quoted: 822 Post(s)
Liked: 182
I would get an Antennacraft HBU22 from Radioshack and perhaps a Winegard 269 preamp. A little more gain would give you a better shot at Baltimore in addition to DC. Maybe add a rotor unless you can find a sweet spot. Another similar antenna, Winegard 7694 would have a bit better build quality. But that RCA 751 should work fine for just DC unless you are in a problematic reception area. And if more gain is needed for Baltimore, the next step up would be HBU33 or 7696.
tylerSC is online now
post #5 of 5 Old 05-29-2012, 03:36 PM
ProjectSHO89's Avatar
Quoted: 288 Post(s)
Liked: 131
A 751 for $22 is a steal. Get it if you can.
Otherwise, get the C2V instead (or get the VHF upgrade kit for an existing C2) if you like the really compact antennas.
ProjectSHO89 is offline
Reply HDTV Technical
