HD STB Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-02-2012, 01:55 PM - Thread Starter
spongebob's Avatar
Quoted: 38 Post(s)
Guys
My friend just inherited a 2003 Zenith C27V22 "HDTV Monitor" that has a coax/antenna input. All he has is an OTA antenna. This sets tuner would not receive any OTA stations and we know the antenna is functioning.
Is there a tuner/converter that takes OTA input and outputs HD through component out? The set only has component or RGB HD inputs. Is the problem that the built in tuner is pre-conversion?
thx
bob
spongebob is offline
post #2 of 11 Old 06-02-2012, 02:06 PM
jjeff's Avatar
Quoted: 688 Post(s)
Liked: 245
A HD tuner with component output is probably going to cost more than it's worth(>$100). With a TV that small I'd really suggest just a quality CECB(SD converter box) which can be had used on Craigslist and other places for ~$20. ~$50 new but not that great quality for currently available models.
CECB forum The CM7000 is almost HD like via S-video and the Zenith/Insignia models are also good via composite.
HD Converter box thread if you really want to go HD.
jjeff is online now
post #3 of 11 Old 06-02-2012, 02:29 PM - Thread Starter
spongebob's Avatar
Quoted: 38 Post(s)
Thanks, Jeff
He has a decent SD converter. Just wanted to kick him up a notch I posted over on the converter box thread, too.
bob
post #4 of 11 Old 06-02-2012, 02:30 PM - Thread Starter
spongebob's Avatar
Quoted: 38 Post(s)
BTW, what do I search for, ebay, CL? HD Converter? Find too much other stuff not realated on ebay.
bob
post #5 of 11 Old 06-02-2012, 05:37 PM
jjeff's Avatar
Quoted: 688 Post(s)
Liked: 245
bob
I haven't really seen HD converter boxes on CL, more in the line of SD CECBs and I don't really do ebay. I've seen a HD box somewhere online(can't remember where) that had VGA as one of it's outputs, I believe under $100 and maybe closer to $80. I think it was a Kworld and I thought it was at Microcenter but I couldn't find it now, maybe they ran out, it was probably old stock.
jjeff is online now
post #6 of 11 Old 06-03-2012, 09:43 AM
Super Moderator
DrDon's Avatar
Quoted: 870 Post(s)
Liked: 1729
All you need to know is here: http://www.avsforum.com/avs-vb/showthread.php?t=179095
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #7 of 11 Old 06-03-2012, 05:00 PM
mikepier's Avatar
Quoted: 16 Post(s)
Guys
thx
bob
That TV was manufactured in 2003. It only has an analog tuner, not digital, so thats why you will not get any channels off your antenna.
Also that screen is only 4:3, it's not even widescreen. Even if you did get an external tuner and watched it in widescreen mode with bars on top and bottom, it will look so small like you are watching a 22" HDTV.
There are many 32" HDTV's out there reasonably priced that has internal digital tuners that will probably be better than you paying for an external tuner that will not even give you a full widescreen picture on your tv.
mikepier is offline
post #8 of 11 Old 06-03-2012, 05:01 PM
Ken H's Avatar
Topic title edited.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #9 of 11 Old 06-03-2012, 05:06 PM - Thread Starter
spongebob's Avatar
Quoted: 38 Post(s)
Thanks, Good advice!
bob
post #10 of 11 Old 06-03-2012, 05:07 PM - Thread Starter
spongebob's Avatar
Quoted: 38 Post(s)
Originally Posted by Ken H View Post
Topic title edited.
I tried right after I posted but it wouldn't let me!
bob
post #11 of 11 Old 06-03-2012, 07:28 PM
Ken H's Avatar
There are many 32" HDTV's out there reasonably priced that has internal digital tuners that will probably be better.....
+1, around $200.
Ken H is offline
Reply HDTV Technical
