Which big Vizio HDTVs for computer usage and watching TV, movies, fullscreen videos, etc.? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-11-2012, 09:11 PM - Thread Starter
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 310
Hello.
I'd like to get a big HDTV that will work with both computer (Windows, Linux, and Mac OS X) screens (gaming, videos, work, etc.) and watching medias (TV shows/series, movies, etc. through cable TV and OTA). Also, I would like to have many options for inputs (VGA [still using an old KVM from Y2K], DVI, HDMI, etc.) and outputs. Which ones would work for my needs?
phildaant is offline
post #2 of 5 Old 06-14-2012, 04:45 PM
Rick_R's Avatar
My Vizio TVs have VGA inputs. However be careful because widescreen HDTVs are 16x9 but widescreen computer monitors are 16x10. Make sure your computer can handle 16x9 or your picture will be squished.
Rick R
Rick_R is offline
post #3 of 5 Old 06-14-2012, 04:50 PM - Thread Starter
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 310
Rick R
Hopefully, it will let me use DVI (no adapters) directly like I do with my Samsung LCD 19" monitor with dual ports (VGA and DVI) so I can tell my video card not to stretch and to keep the aspect ratio (don't mind the borders). smile.gif
post #4 of 5 Old 06-16-2012, 01:34 PM
gbynum's Avatar
Quoted: 25 Post(s)
Rick R
I think you'll find that most newer monitors are 16:9 also ... indeed, it is almost hard to find a 16:10, 1920x1200.
gbynum is offline
post #5 of 5 Old 06-16-2012, 01:52 PM - Thread Starter
phildaant's Avatar
Quoted: 857 Post(s)
Liked: 310
Resolutions doesn't bother me as long as they are big and I can tell my video cards not to stretch in horrible aspect ratios if not native. I don't mind the black borders either.
Reply HDTV Technical
