Attic Antenna in COLUMBIA, SC. Only missing one station! Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-22-2012, 10:46 AM - Thread Starter
m0tion's Avatar
I have a Winegard 7697p connected to a Channel Master CM-7777 preamplifier mounted in my garage attic (equivalent of a second floor). Below is my TVFool chart. I get "good" reception according to my television on all of the yello and pink channels EXCEPT Fox (48 / 57.1). My TV doesn't even pick it up when I do a channel scan. I am having a hard time understanding this because I get good reception on MyN (39 / 63.1) which appears to be broadcast from the same tower according to the TVFool info? Any ideas?
576
m0tion is offline
post #2 of 3 Old 06-22-2012, 06:39 PM
ProjectSHO89's Avatar
Quoted: 210 Post(s)
Liked: 110
Relocate the antenna. It's in a "dead spot" for that station.
ProjectSHO89 is offline
post #3 of 3 Old 06-24-2012, 12:34 PM
mikepier's Avatar
Quoted: 16 Post(s)
If relocating the antenna does not work, try the antenna outside. Even though Fox is 29 miles away, it is at 2 edge reception, which is iffy for an antenna thats in the attic.
mikepier is offline
Reply HDTV Technical
Winegard , Channel Master Cm 7777 Titan2 Uhf Vhf Preamplifier Cm7777 , Component Preamplifiers
