Need Lamp Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-24-2012, 09:43 AM - Thread Starter
Bruno88's Avatar
Hello everyone first post on the site and need some help with determining a problem. When I turn my TV on, the little display thing turns on and then shuts off repeatedly, the tv itself never turns on.
This is the TV:
http://www.amazon.com/Samsung-HLP5685W-HDTV-Ready-DLP-Rear-Projection/dp/B0002MLXAC/ref=sr_1_2?s=electronics&ie=UTF8&qid=1340556002&sr=1-2&keywords=SAMSUNG+HL-P5685W
Replacement Lamp (Not sure if this is the right one)
http://www.amazon.com/SAMSUNG-HL-P5685W-Replacement-projection-BP96-00677A/dp/B0012N0XME/ref=dp_cp_ob_e_title_0
* Im not that much of a TV repair expert, but I believe it is the lamp itself. Please give me your input.
Steve
Bruno88 is offline
Reply HDTV Technical
Displays , Samsung , Projectors
