Things to look for before buying LED TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-25-2012, 07:29 PM - Thread Starter
itsgonabeme's Avatar
Hi Experts/Gurus,
I am planning to purchase a Sharp 55 LED TV from craiglist, i understand the LED is used and there is risk but it is saving me lots of money.
I would really appreciate if you can get me some pointers on what to look for?
What shall i check to make sure the unit i am buying a right led?
Will look forward to hear from you.
Sam
itsgonabeme is offline
post #2 of 2 Old 06-26-2012, 06:43 AM
Beerstalker's Avatar
Liked: 24
You'd be better off reading around/asking in this forum.
http://www.avsforum.com/f/166/lcd-flat-panel-displays
Beerstalker is offline
Reply HDTV Technical
Led Hdtv , Sharp , Haier 55 Inch Led Hdtv Le55b1381 , Displays
