Comcast Local Channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-01-2012, 01:08 AM - Thread Starter
Mountain Dave's Avatar
Comcast just migrated to all digital in my area. Before I could get local channels on my HDTV with the digital QAM tuner, w/o any cable box. Now all the local channels are gone. I know Comcast is a looser, but I have no choice in my area. Can they encrypt local QAM channels if you subscribe to basic cable? They sent everyone a stupid digital converter box, but all it does is convert Comcast's digital signal to an analog signal so I can plug it into my digital tuner. Dumb! BTW, I have done a channel search several times.
Thanks for any help.
Mountain Dave is offline
post #2 of 2 Old 07-01-2012, 02:04 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Pop your zipcode in here: http://www.silicondust.com/support/channels/ and pick your cable service from the next page. That should tell you if they're still there.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply HDTV Technical
