OTA Lexington Stations in Morehead, KY - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-12-2012, 03:41 PM - Thread Starter
tnd2252's Avatar
I'm searching for an antenna that will allow me to pick up CBS, NBC, ABC & FOX. I have a ClearStream1 Convertible, but as of right now I can only pick up KET. Three different KET's to be honest. I'm looking for a way to pick up the Olympics this summer and NFL this fall.
TV Fool info
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d990075626beb32
tnd2252 is offline
post #2 of 2 Old 07-12-2012, 06:32 PM
rabbit73's Avatar
Quoted: 400 Post(s)
Liked: 159
tnd2252:
Welcome to the forum.
Your tvfool report doesn't look very hopeful. Please try it again using your exact coordinates, for a more accurate report with your difficult terrain. Your report puts you near the intersection of Johnson Rd and 519.
What you are receiving is WKMR:
http://www.rabbitears.info/market.php?request=station_search&callsign=WKMR
I tried an approximate report for your area and I needed to put your antenna up 300 ft for LOS signals:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d9900b60088a8de
I don't think it's just a matter of a better antenna, but getting it up much higher to receive what you want.
You are going to need something at least like an Antennas Direct DB4e or better yet a 91XG aimed at 265 degrees. You will also need a preamp. Even this setup might not be enough; no guarantees.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
Reply HDTV Technical
