Antenna Choice For Channel 38 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-13-2012, 08:18 PM - Thread Starter
lovebohn's Avatar
My only choice for NBC (WEAU) just switched from channel 13 (which came in great with a dedicated Wade from 70 miles) to channel 38. I have an old CM4228 which I love but I'm having to many drop outs with it. What antenna will work the best for channel 38?
Dave
lovebohn is offline
post #2 of 6 Old 07-13-2012, 08:22 PM - Thread Starter
lovebohn's Avatar
Btw this can be a directional dedicated antenna for 38. If this works fine I will add a tin lee combiner since joitennas are gone.
lovebohn is offline
post #3 of 6 Old 07-14-2012, 03:52 AM
BCF68's Avatar
Post a TVFool report and we might actually be able to help you.
BCF68 is offline
post #4 of 6 Old 07-14-2012, 04:36 AM
ProjectSHO89's Avatar
Quoted: 288 Post(s)
Liked: 131
The 91XG is about as good as you're going to get on UHF 38 unless you can come up with an old ChannelMaster parabolic. You might want to gang two of the 91XGs.
ProjectSHO89 is offline
post #5 of 6 Old 07-14-2012, 07:15 AM
tylerSC's Avatar
Quoted: 821 Post(s)
Liked: 182
The original Channel Master antennas are now very hard to find, including the 4248 and 4257 UHF Diamand Quantum yagis. Those are similar to the 91XG type of design and very good performers. PCT now owns the CM name and outsources Chinese made imitations. Also the original CM7777 preamp as been discontinued. But PCT does make very good distribution amplifiers under the CM name. As for now, the 91XG or the Fracarro 920 may be the best UHF antennas available, and you could also look at Winegard 9095 or 9032.
tylerSC is offline
post #6 of 6 Old 07-14-2012, 01:30 PM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
You may only need one 91-XG. I have personally found it to be superior to the original 4228 in metropolitan, suburban & fringe environments.
Digital Rules is offline
Reply HDTV Technical
