Does Coax cable to HDMI adapter or converter exist? No - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-15-2012, 05:09 PM - Thread Starter
SilverBlade's Avatar
Quoted: 84 Post(s)
Liked: 25
I am wondering if such a product exits:
Coax cable to HDMI adapter or converter.
I am NOT looking to extend an HDMI signal over coax cable.
Coax cables are ridged, and very hard to put into *any* cable management scheme as they are harder to bend, where HDMI cables are far more flexible and can take sharp corners far easier than coax cables.
SilverBlade is offline
post #2 of 9 Old 07-15-2012, 05:17 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
Coax cables "are what they are" for a reason. The requirements for carrying an RF signal with minimal signal loss or degradation dictates the construction and physical chracteristics of the cable.
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #3 of 9 Old 07-15-2012, 06:38 PM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
That's like asking for apples to look and taste oranges.
Ratman is online now
post #4 of 9 Old 07-15-2012, 08:28 PM
Colm's Avatar
Liked: 94
Originally Posted by SilverBlade View Post
...HDMI cables are far more flexible and can take sharp corners far easier than coax cables.
Not without damaging them...Both coaxial and HDMI cables have minimum bend radii.
Is this for analog audio or video/digital audio cables? For analog audio, you can get cheap patch cords that are flexible enough to tie in a knot, and they work just fine. For video/digital audio, you can use a balun that converts from coax to Cat 5/5e/6.
Colm is offline
post #5 of 9 Old 07-16-2012, 09:40 AM
Beerstalker's Avatar
Liked: 24
I assume you are talking about RG59/RG6 coax or RF cables, not coax digital audio cables?
If so there are some cable manufacturers out there who make RG6 cables that are very flexible and work well, however they tend to be much more expensive. This is one thing that I did actually like about Monster Cable, they made some very nice, flexible RG6 cables. I actually have one RG6 cable that is about 50 foot long where the wire is only about an 1/8" in diameter and very flexible. It actually worked great and I used it for years in my old apartment where I had to run the coax from one wall around the edge of the room to the oppisite wall to get to my HD-DVR. It worked fine with both Comcast HD service as well as DirecTV HD service.
I just checked and Monster doesn't make the really thin cable like I have anymore, but the do seem to still make some of the other cables like I had.
http://www.monstercable.com/productdisplay.asp?pin=3834
These are much more flexible than regular coax cables, so it might be worth trying out.
And before everyone jumps on me about Monster being a ripoff, etc. I know that and I normally wouldn't recommend them. I usually buy all my cables from Monoprice, but in this particular instance where the poster is looking for a more flexible coax I think this may be an option.
Beerstalker is offline
post #6 of 9 Old 07-16-2012, 05:12 PM
cgmv123's Avatar
Quoted: 40 Post(s)
Liked: 36
cgmv123 is offline
post #7 of 9 Old 07-17-2012, 06:03 PM
Super Moderator
DrDon's Avatar
Quoted: 869 Post(s)
Liked: 1727
Please keep thread titles specific. See my edit.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #8 of 9 Old 08-21-2013, 02:54 PM
Lito Nane's Avatar
Lito Nane is offline
post #9 of 9 Old 01-03-2015, 07:46 PM
PANASONICPZ85U's Avatar
I need to push hdmi into my dvr and the only input to the magnavox dvr (2009) is a coax input.
Because Buckeye Cablesystem in northwest ohio requires me to connect now via their hdta digital box, the only signal carrying hd coming out of their box has to go out on the hdta's hdmi out jack, yet the magnavox only has a coax input.
Currently I have it connected with the coax out jack from the hdta out .
So of course I would at a minimum want to leave the hdta with hdmi out jack and an hdmi cable, then "pass it thru" a converter that then outputs it to coax wire yet maintains the hd, and at best just have a wire or cable that has hdmi at one end and coax at the other end. (this does not exist i presume, but perhaps the former does)
PANASONICPZ85U is offline
Reply HDTV Technical
